Temperature Sensor Location: Installation Guide
harj
Post26-08-2004, 11:14    Subject: Temperature Sensor Location: Installation Guide Quote
Hello everyone.
Do you know where the coolant temperature sensor is located on the AFB (Airborne Forward Base)?
How does the engine control unit measure this temperature?
Sincerely,
Sepp.
Translated on 02-08-2026, 9:07.
Autofitti
Post26-08-2004, 18:22    Subject: Temperature Sensor Location: AFB Engine Quote
Hello, remove the upper engine cover. The sensor is located at the front, slightly to the left of center. It has 4 pins and is blue or bluish-green. It supplies power to the engine control unit and the temperature gauge in the instrument cluster. Hella part numbers for replacement parts: up to model year X (1999): 6PT 009 107 541, from model year 2000 (Y): 6PT 009 107 141. Prices: approximately 20 Euros. (A picture of the engine compartment with the installed sensors and actuators is available if needed).
Translated on 02-08-2026, 9:08.
harj
Post27-08-2004, 5:42    Subject: AFB Engine Temperature Sensor Quote
Hello.
Are these two separate sensors or just one sensor housed within a unit for the control module and display?
Sincerely,
Sepp.
Translated on 02-08-2026, 9:10.
Autofitti
Post27-08-2004, 10:39    Subject: Temperature Sensor: Buy Now! Quote
Hello again,
for both parameters in a sensor with 4 pins.
neubaupe
Post13-11-2006, 21:41    Subject: Temperature Sensor Location: Installation Guide Quote
It's really important right now because everything is being taken apart.
Which cable carries the signal to the control unit for the 4-pin coolant temperature sensor?
I don't want to disconnect the short cables just in case.
(Implementation of a workaround for the ULF warm start issue.)
Best regards.
Peter.
Translated on 02-08-2026, 9:11.
Autofitti
Post14-11-2006, 8:33    Subject: Temperature Sensor Location: Installation Guide Quote
What kind of vehicle and engine are we talking about? Otherwise, you might try to rip me off icon_twisted.gif.
If the car has already been driven a long way and the starter motor is in very poor condition (stage 3 of deterioration), then replace it; that's likely the cause of the problem, and once you do that, the issue will be resolved.
Translated on 02-08-2026, 9:12.
neubaupe
Post14-11-2006, 10:21    Subject: Temperature Sensor Location: Installation Guide Quote
which vehicle and which engine
This is a 1.9 TDI AFN engine from 1998 in a Seat Ibiza 6K.
On the 4-pin coolant temperature sensor.
There were two blue wires, one yellow wire, and one brown wire.
The brown substance was located near the coolant on the metal sheet.
outlet flange fastened (grounding?)
Cause of the problem
The warm-start problem cannot be solved so easily.
für jedes Fahrzeug pauschalisieren. It's true.
that enough people have already written.
that after replacing the battery, starting the engine...
once it has been properly restored to a working condition after being exposed to heat.
However, that wasn't the case for me. The starter motor is brand new.
The battery is pretty much dead (only 300 rpm at startup).
However, the problem has hardly changed since I was two years old.
I haven't had a new battery in years, just like...
like last time after the spark plug replacement.
If you disconnect the coolant temperature sensor, it will be...
in a very hot condition with an old starter and weak.
Battery - even immediately after being turned off - during a start.
versuch SOFORT da. (heisst er springt fast auf 1. (Compression on)
Since there was almost no change in symptoms after replacing the hardware on my...
It was difficult to determine, and there were enough statements about the conditional.
Meaningfulness of the AFN STG software in relation to warm start functionality.
I will now implement the concept that Ulf has been developing.
Okay, can someone tell me which cable comes from the 4-pin connector?
Does the KüTempSensor provide a signal to the control unit (ECU)?
Thanks, best regards.
Peter.
'PS:'
If the cables weren't so incredibly short at this point...
I wouldn't post it here, but rather disconnect it based on suspicion.[/b]
Translated on 02-08-2026, 9:16.
Autofitti
Post14-11-2006, 11:56    Subject: Temperature Sensor Location: Installation Guide Quote
Connect the signal wire from the temperature sensor to pin 3 on the connector that connects to the control unit. Pin 3 is the lower left pin when the two adjacent protrusions on the connector are facing upwards. I don't know the color of the wire. I can rule out brown and yellow-brown.
Translated on 02-08-2026, 9:20.
neubaupe
Post15-11-2006, 16:36    Subject: Temperature Sensor Location: Installation Guide Quote
You're welcome, Autofitti!
Best regards.
Peter.
Autofitti
Post15-11-2006, 20:17    Subject: Temperature Sensor Location: Installation Guide Quote
You're welcome.
Translated on 02-08-2026, 9:21.
No new posts Error code P1115, Overvoltage Temperature Sensor General Tips
No new posts P2185 - Coolant Temperature Sensor, High Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Position Temperature Sensor Transmission, Chassis, Body & Interior
No new posts Coolant Temperature Sensor AFN Diesel Engine Technology
No new posts Coolant Leak - Temperature Sensor Diesel Engine Technology
No new posts Temperature sensor for climate control is faulty. Diesel Engine Technology
