Warm clutch jerks
Go to page: 1, 2  Next
bastion
Karma: +6 / -1   Thank you, like it!
Post06-09-2006, 13:22    Subject: Warm clutch jerks Quote
When my clutch is warm, it starts to slip. It's especially noticeable when I've been driving in the city for a while.
The more the clutch is stressed, the stronger the jerking becomes. In other words, the more heat is generated, the more it jerks.
When the clutch pedal is pressed, it makes a creaking sound. When the car is stationary, a squealing noise can be heard from outside after about halfway through the pedal's travel. When the engine is running, only the creaking sound can be heard inside the car.
The pedal was already squeaking before the clutch started to slip.
GKB is CPC.
A4 Avant 08/01 AWX 05/08-
Translated on 17-07-2026, 17:41.
BM
Avatar-BM
Post06-09-2006, 14:24    Subject: Warm clutch jerks Quote
The more the clutch is stressed, the stronger the jerking becomes. So, the more heat is generated, the stronger the jerking.}
It's possible that the clutch is worn out and no longer providing consistent friction. Normally, they should last for at least 200,000 km with reasonable driving, but that's relative. I doubt there's a defect in the master or slave cylinder, but it should be checked.
If, when starting, you press the pedal far enough that the clutch begins to engage, and then it jerks (without you pressing the pedal further) during the automatic engagement (which happens automatically as the engine speed approaches the vehicle speed or the car starts moving), I suspect the clutch is defective.
3B5 AJM
Translated on 17-07-2026, 17:43.
bastion
Post06-09-2006, 14:31    Subject: Warm clutch jerks Quote
If, when starting, you release the pedal until the clutch starts to engage, and then it jerks (without you releasing the pedal further) during the automatic engagement (which happens automatically as the speeds approach or the vehicle starts moving), I assume that the clutch is defective.
I will test it.
How can I actually test the master and slave cylinders? Does it require them to be removed for testing?
Translated on 17-07-2026, 17:44.
Post06-09-2006, 15:54    Subject: Warm clutch jerks Quote
"Mine does that creaking sound too, but it doesn't pull or tug."
The creaking is also clearly dependent on temperature.
"But it's been happening for a long time now (I've had the car for over 100,000 km and it only disappeared at the beginning), and the clutch should still be the original one – with 227,000 km on the clock."
Translated on 17-07-2026, 17:46.
pax
Avatar-pax
2000 Volkswagen Passat
Post06-09-2006, 20:39    Subject: Warm clutch jerks Quote
Hello bastion,
"The clutch judder issue is also occasionally discussed in the Passat forum. There probably isn't a 100% solution for it. My Passat is affected by this problem as well."
Following a tip from some diesel mechanics, I tried the "burn-off" method – starting in 3rd gear until it starts to smell bad.
It actually helped for about half a year. However, you wear out your clutch quite quickly that way.
Bye.
peace
Translated on 17-07-2026, 17:47.
Herr Antje
Post07-09-2006, 8:01    Subject: Warm clutch jerks Quote
The creaking could also be related to the pedal's mounting rather than the clutch itself. In that case, replacement is probably the only solution (greasing likely won't be a permanent fix). Unfortunately, I don't know if the mounting parts are available separately. I have the same issue, but it doesn't bother me, so I've never taken it apart.
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 17-07-2026, 17:48.
Post07-09-2006, 8:22    Subject: Warm clutch jerks Quote
Nope, Antje icon_wink.gif.
The squeaking I'm hearing definitely comes from the clutch, because you can't hear the pedal bearing squeak coming from the clutch bell.
It's probably a worn-out thrust bearing, or the two contact points where the finger presses against the A-bearing are too dry.
Translated on 17-07-2026, 17:49.
makrospex
Post07-09-2006, 8:23    Subject: Warm clutch jerks Quote
Take a look through the inspection hole in your clutch housing.
I also experienced clutch judder, vibrations when starting, and a very short pedal travel before reaching the engagement point.
Dual-mass flywheel and release lever defective.
"When the clutch started squeaking while starting uphill at 150,000 km (previous four owners), we could see through the inspection hole that there was no more friction material visible on the clutch disc. After that, we completely replaced the dual-mass flywheel (DMF), pressure plate, clutch disc, and release lever -> problem solved."
In my case, the costs were quite high (1,600 euros), but I will get them back because I sued the dealer for a price reduction. He refused to acknowledge that the dual-mass flywheel (DMF) was defective, couldn't fix the starting problems that had existed since the purchase, and ultimately didn't want to. For that, I paid 600 euros above the list price for a '1-year full warranty'. icon_evil.gif
greetings,
macro
Translated on 17-07-2026, 17:51.
Herr Antje
Post07-09-2006, 8:33    Subject: Subject: Clutch slipping/grabbing Quote
@dieselmartinViewing profile: dieselmartin
I wasn't referring to your specific situation, but rather to that statement.
bastion wrote:
When the clutch pedal is pressed, it makes a slight creaking noise. When the car is stationary, a squeaking sound can be heard from outside after about half of the pedal's travel. When the engine is running, only the creaking noise can be heard inside.
It sounds like there's a creaking noise coming from the pedal and a squealing sound from the clutch, so it seems we have two separate issues.
Aktuell:
Translated on 17-07-2026, 17:53.
Post07-09-2006, 9:00    Subject: Warm clutch jerks Quote
@antje
Ah, okay, then I misunderstood something.
@makro
I highly doubt that the AHU engine has a dual-mass flywheel (DMF); as a 1Z-engine variant, it's very unlikely.
Translated on 17-07-2026, 17:54.
mullemaus
Post07-09-2006, 15:14    Subject: Warm clutch jerks Quote
It depends on the year of manufacture; the first ones didn't have one. From engine number AHU *200 001 onwards, it should be a 2MSR. 028 105 266 A icon_wink.gif.
Translated on 17-07-2026, 17:55.
bastion
Post08-09-2006, 6:38    Subject: Warm clutch jerks Quote
BM wrote:
If, when starting, you release the pedal until the clutch begins to engage, and then it jerks (without you releasing the pedal further) during automatic engagement (which happens automatically as the engine speeds approach or the vehicle starts moving), I assume that the clutch is defective.
I checked it. No pulling/tearing present.
I submitted the GKB (CPC). It should indicate whether or not it has a ZMS.
EDIT:
Could it be that I might have low transmission fluid?
EDIT2:
Regarding the squeaking noise: The squeaking is coming from the master cylinder. You can really feel it when you press the clutch pedal and touch the "push rod."
Translated on 17-07-2026, 17:56.
BM
Avatar-BM
Post08-09-2006, 13:43    Subject: Warm clutch jerks Quote
Regarding the squeaking: The squeaking comes from the master cylinder. You can really feel the squeaking when you press the clutch pedal and touch the "push rod" at the same time.
If you're sure the noise is coming from the master cylinder itself and not being transmitted from the clutch, I would start by replacing the cylinder.
I still wouldn't get my hopes up that she will stop doing that afterward.
Six weeks ago, I replaced the slipping clutch on a Go4 with 318,000 km (from Luk to Sachs). The dual-mass flywheel (DMF) was not replaced at the owner's request due to cost considerations.
Result: No more inflammation present.
Could it be that I might have low oil levels in the transmission?
Of course that could be the case, but it has nothing to do with plucking.
3B5 AJM
Translated on 17-07-2026, 17:58.
bastion
Post11-09-2006, 10:49    Subject: Warm clutch jerks Quote
Yesterday, I noticed something else. If I repeatedly press and release the clutch pedal without engaging a gear, the squeaking goes away for a short time.
Also, if the clutch slips after driving in the city, and if I continue driving for a while without shifting gears, the slipping stops.
Translated on 17-07-2026, 17:59.
bastion
Post13-09-2006, 14:18    Subject: Warm clutch jerks Quote
makrospex wrote:
Take a look through the viewing hole in your clutch housing.
When the clutch started making a squeaking noise when starting uphill at 150,000 km (four previous owners), you could see through the inspection hole that there was no lining left on the clutch disc. After that, a complete replacement of the dual-mass flywheel (DMF), pressure plate, clutch disc, including the release lever -> problem solved.
Where is the inspection hole located on my gearbox?
Translated on 17-07-2026, 18:01.
makrospex
Post14-09-2006, 18:14    Subject: Warm clutch jerks Quote
So, if it has a viewing hole, then it is covered by a round rubber cap, approximately 8x4 cm in size.
Right on top of the clutch housing, closer to the engine than to the transmission.
There's even a small handle on it for opening.
Unfortunately, I don't have a photo available at the moment.
macro
Translated on 17-07-2026, 18:02.
No new posts Noise / Clutch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Squeal: A3 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Clutch Slipping - 81kW Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Slipping: Causes and Solutions Transmission, Chassis, Body & Interior
No new posts Clutch Slipping? Common Causes & Solutions. Diesel Engine Technology
No new posts Clutch Slipping After 7k Miles: Why? Diesel Engine Technology
No new posts Clutch jerks when starting, especially in warm weather (A... Transmission, Chassis, Body & Interior
