Franz79
20-09-2005, 18:50 Subject: Eberspächer D4WSC Problems: Troubleshooting & Help |
So, my problem starts with the cold season.
I also have the TP5 remote control.
What I need to say right from the beginning is that the STH (presumably referring to a specific component or system) was installed by me.
Okay, now for the problem: It's annoying because sometimes it works perfectly, and other times it doesn't work at all. I always get different error codes when it refuses to start. I've completely disassembled the device numerous times, cleaned everything, and checked it, then reassembled it. Great, it works fine for a few days. But then it stops working again. As I mentioned, the error codes I read using the TP5 remote are very varied. Sometimes it's just the flame sensor, then suddenly it's the control unit. Ten minutes later, it works perfectly again. Currently, the problem is that the heater isn't even pumping diesel. It starts making noise (the fan), but doesn't ignite. The relay for the interior fan is also not switching on at the moment (although it's not broken).
Maybe someone has some tips for me.
Franz
Translated on 04-10-2026, 0:48.
brezelmann01 Profi-Schrauber
Joined: 09/14/2002 Posts: 714 Karma: +75 / -0 Location: Niedersachsen
20-09-2005, 19:33 Subject: Eberspächer D4WSC Problems: Troubleshooting & Help |
Hi!
Have you tried searching for "Eberspächer D4WSC"? There's a post there that might be helpful to you. Apparently, Eberspächer control units are actually quite prone to problems...
Dirk.
Translated on 04-10-2026, 0:50.
Klima96 Blaumann
Joined: 08/26/2004 Posts: 39 Karma: +6 / -1 Location: Sauerland
21-09-2005, 16:46 Subject: Eberspächer D4WSC Problems: Troubleshooting & Help |
Hello.
Did you really install them according to the instructions?
I've often encountered self-installed components that were not installed in the correct orientation.
"installed!"
Or, out of convenience, simply tapped into the diesel line somewhere, and didn't...
They installed a separate riser pipe inside the tank.
Then, problems like the ones you described could occur.
Do you have the 2-page EB error code tables?
Golf 4 TDI PD 96 KW 6 Gang ASZ ERF
Jetzt 114 Kw nach *** Chip
Translated on 04-10-2026, 0:51.
Franz79
21-09-2005, 17:36 Subject: Eberspächer D4WSC Problems: Troubleshooting & Help |
The thermostat housing is definitely installed incorrectly. I thought it was just a problem with bleeding the coolant. I always installed it in the correct orientation for bleeding (because of the bleed screw) and then turned it upside down when installing it.
Could that be the cause...? Why does it sometimes work then?
Franz
Translated on 04-10-2026, 0:52.
Bakkybfast
10-10-2005, 8:47 Subject: Eberspächer D4WSC Problems: Troubleshooting & Help |
@ Franz79
Can you describe how to use the TP5 remote control to display the error code?
can be read out?
It would also be great if someone knows how to unlock the restriction.
can be done if you don't have a VAG-Com. Is it also possible to do this with the hand-held device?
I am grateful for any help and tips.
Translated on 04-10-2026, 0:53.
ND
12-10-2006, 13:09 Subject: TP5: Read Error Codes with Remote Control |
Hello Franz79,
I'm also having the problem with my Eberspächer Hydronic 4 where the auxiliary heater is no longer igniting.
Can you please describe how to read error codes using the TP5 remote control?
Thank you very much.
ND
Translated on 04-10-2026, 0:54.
tdi-schrauber Blaumann
14-10-2006, 22:15 Subject: Eberspächer D4WSC Problems: Troubleshooting & Help |
Hello!
Turn on the TP5 using the power button.
Taste P zweimal drücken. Time is blinking.
Press and hold the "P" button for two seconds: "oooo" will appear.
Press the "Heating" button.
Press the P key.
Press the "Heating" button twice.
Press the P key.
TP5 reads error codes.
Display Fxyy, where x indicates the number of errors (0-5) and yy represents the error code (-- = no error).
Taste UP und DOWN zeigen evtl. gespeicherte Fehler. Fehlernummern lt. Manual.
Clear errors and unlock.
Press the P key, display shows "deL".
Press and hold the heating button for 2 seconds.
BYE
TDI mechanics.
Translated on 04-10-2026, 0:55.
Vau6
14-11-2006, 19:04 Subject: Eberspächer D4WSC Problems: Troubleshooting & Help |
Hello.
TDI mechanics!
I fixed the issues with my BW5 SC using the brilliant guide for the TP5.
I have errors in the following: F 130, F230, F330?
Where can I break these down?
Thank you in advance.
Translated on 04-10-2026, 0:57.
Vau6
14-11-2006, 19:45 Subject: Eberspächer D4WSC Problems: Troubleshooting & Help |
Hello.
I figured it out myself.
Error code 030.
Is the burner motor not working?
How can I find out more about them?
Translated on 04-10-2026, 0:58.
Vau6
19-11-2006, 18:46 Subject: Eberspächer D4WSC Problems: Troubleshooting & Help |
Hello.
Bug fixed.
The auxiliary heater had been removed.
It was quite quick to do. I disconnected the two hoses, unplugged the connector, and removed the exhaust pipe. I left the air duct connected. I unscrewed the long M6 bolt on the side of the heater, and then the heater almost falls out of its bracket.
After opening the upper black plastic cover of the heater, I first checked the electric motor. I connected a 12V battery, and the motor worked. Next, I examined the round beige fan of the combustion air blower. This was a bit stiff. Dirt, sand, and debris had accumulated under the fan, making it difficult to turn. I could hear the sand crunching underneath as I turned it. After blowing everything out with compressed air and applying some oil, the blower started running smoothly again. After reassembling and installing the heater, it started up immediately! This was the source of the problem. The control unit completely shuts off the heater with even the slightest resistance. The cause of the error is a lack of sealing between the upper and lower parts of the housing. Over time, dirt gets in because there is no seal. I will address this soon by using special silicone sealant.
Translated on 04-10-2026, 0:59.
