110 hp TDI too slow???????
MONCHI
Post07-11-2002, 14:13    Subject: 110 hp TDI too slow??????? Quote
Hi and Hello,
I just have a quick question.
I have a 1998 Seat Ibiza GT TDI with a 110 horsepower AFN engine.
The car has a powerbox from KW-Systems, a new mass airflow sensor, and a Twister-Kit air filter. The performance is according to... Dyno test: 139.8 horsepower / 296 Nm of torque.
Please provide the text you would like me to translate from German to English.
The car is certainly fast, but a BMW 320d (150 hp) is still faster from 100-200 km/h, even though it's much heavier than my Ibiza (tare weight 1,120 kg). I might be faster in acceleration, but I have no chance in terms of responsiveness. That's why I don't think a 110 hp TDI can be faster than, for example, a Golf 4 GTI TDI with 150 hp!!??
Is it possible to remove the rev limiter? Does anyone have any experience with that? 'At just under 220 km/h, that's my limit!'
Monchi.
Stefan
Post07-11-2002, 14:37    Subject: 110 hp TDI too slow??????? Quote
Without wanting to offend you:
Could it be that you're driving the wrong car?
'That BMW is a real rocket. It's possible that you might be faster from 0 to 100, but I also believe that the BMW is better from 100 to 200.'
'If your car runs at 220 km/h, be happy with that. Removing the speed limiter is not only difficult, and even if you find a tuner who can do it, your engine is likely to fail soon. There's a reason why the engine is limited in the first place. A diesel engine is not the same as a gasoline engine. Diesel fuel burns much slower than gasoline. As the engine speed increases, the time window for the combustion process becomes increasingly narrow. If you rev the engine even higher, eventually the time window will be too short, and you will get engine damage (not due to mechanical over-revving, as with a gasoline engine).'
If you still want to 'push' the BMW, get a good chip and install the VNT-17. Then you'll get a lot more power.
kenny
Post07-11-2002, 15:59    Subject: 110 hp TDI too slow??????? Quote
I would have swapped my 110hp TDI for a 320d a long time ago if I only had the money, because even used BMWs aren't that expensive - unless you buy one with more than 100,000 km on the odometer.
A friend of mine has a 320d, and I personally like it much better than the VW. The transmission shifts wonderfully, and it responds very directly to the accelerator, with great acceleration. It revs smoothly – not as abruptly as the VW PD-TDIs, and if you drive long distances, especially at speeds above 160 km/h, it's also much more fuel-efficient, saving around 1 to 1.5 liters per 100 km.
No new posts Golf4: Turn signals flickering, wipers too slow, lights t... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ölstand nimmt langsam zu Diesel Engine Technology
No new posts USB Connection Slow: HEX-NET or HEX-V2? On-Board Diagnostics (OBD)
No new posts Kupplungspedal kommt langsam zurück Transmission, Chassis, Body & Interior
No new posts Error 0575: Rule Difference - Troubleshooting Guide On-Board Diagnostics (OBD)
