VW AGR Tester Rate
NorthstarV8
Post25-07-2007, 15:17    Subject: VW AGR Tester Rate Quote
weiß jemand die Schritte bzw. Vorgehensweise bei dem VW Tester z.b. 5051 oder 5052 ? Is it the same here?
/viewtopic.php?t=3095
Thank you in advance.
Ross-Tech-Support
Post25-07-2007, 15:35    Subject: VW AGR Tester Rate Quote
It is similar, depending on which base version is running on the VAS.
NorthstarV8
Post25-07-2007, 16:05    Subject: VW AGR Tester Rate Quote
But do the address codes match?
Ross-Tech-Support
Post26-07-2007, 21:39    Subject: VW AGR Tester Rate Quote
Yes, only the function numbers can differ.
NorthstarV8
Post13-08-2007, 15:10    Subject: VW AGR Tester Rate Quote
My workshop can't figure out the VAG-COM manual. Does anyone know the steps regarding 5051 or 5052?
Ross-Tech-Support
Post13-08-2007, 15:40    Subject: VW AGR Tester Rate Quote
Then you should look for a different workshop, that's basically elementary workshop knowledge...
NorthstarV8
Post13-08-2007, 15:50    Subject: VW AGR Tester Rate Quote
The problem is that the channels apparently don't fit.
Malte1408
Post13-08-2007, 15:53    Subject: VW AGR Tester Rate Quote
What kind of engine do you have, actually?
NorthstarV8
Post13-08-2007, 16:10    Subject: VW AGR Tester Rate Quote
I have a BLT motor.
Malte1408
Post13-08-2007, 23:05    Subject: VW AGR Tester Rate Quote
NorthstarV8 wrote:
I have a BLT motor
While I don't know it, it sounds like EDC16 = different adjustment channels and adaptation of air mass is no longer possible.
Ross-Tech-Support
Post13-08-2007, 23:37    Subject: VW AGR Tester Rate Quote
The BLT should actually be an EDC15, similar to PD-TDI, but uses KWP-1281 as the diagnostic protocol, which the EDC16 does not support. Based on my experience, the adjustment channels and other components are as described in the above article and are known as such. Therefore, I recommend seeking a different workshop.
spajor
Post14-08-2007, 12:35    Subject: Problem with the workshop, I am familiar with. Quote
The mechanic had to ask his colleagues three times how to enter the login code, and then find the channel, and he was very proud that the adaptation had worked... icon_lol.gif
Ölfinger
Post27-09-2007, 19:30    Subject: VW AGR Tester Rate Quote
Can someone now say whether the adjustment of the air mass (AGR rate) can also be done via channel 3 with the VAG 5051/B icon_question.gif
Post27-09-2007, 19:39    Subject: VW AGR Tester Rate Quote
Ölfinger wrote:
Can someone now say whether adjusting the air mass (AGR rate) with the VAG 5051/B also takes place via channel 3 icon_question.gif
yes. This depends not on the device, but on the control unit. ...because it's actually in channel 3 for all EDC15s...
I had already emailed.
Hello, Rainer
No new posts G12 Test: Your Ultimate Guide Diesel Engine Technology
No new posts VAG 1551: Check Injection Start (AEL) Diesel Engine Technology
No new posts Test drive with rebuilt engine. Need advice On-Board Diagnostics (OBD)
No new posts VAG-COM sampling rate Diesel Engine Technology
