Adjust idle speed
Joschis
Post11-12-2006, 22:15    Subject: Adjust idle speed Quote
Hello everyone,
I have a question: "How do I change the idle speed on my car using VAG-COM?"
Volkswagen Passat 3B5, V6 TDI 2.5 liter engine, AFB code, manufactured in October 1999.
I've already found something, but I'm not sure if it's the right thing.
Select the engine control unit.
Please log in to channels 1, 3, 4, and 5 using the username "12233".
Select adaptation.
Select the corresponding channel and change the value (which can only be changed within certain limits).
Channel 1: Injection amount.
Channel 2: Idle speed.
Channel 3: Air mass.
Channel 4: Injection timing.
Channel 5: Starting amount.
VW Passat V6 TDI 2,5
Bj. 10.1999 / AFB
Translated on 18-07-2026, 12:29.
chli1976
Post11-12-2006, 22:49    Subject: Adjust idle speed Quote
With the "Adjust Channel 2" function (option 10), it should work if your control unit supports it.
It works with the 4-cylinder TDI engines, but only within a limited range.
Translated on 18-07-2026, 12:31.
mserge
Post12-12-2006, 12:05    Subject: Adjust idle speed Quote
"I've had an AFB (air flow balance) adjustment done, and I've also had an AKE (acceleration control enhancement), but as I said, only within a specific range, approximately plus or minus 50 RPM."
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 18-07-2026, 12:32.
Ross-Tech-Support
Post12-12-2006, 12:32    Subject: Adjust idle speed Quote
It is very rare that it's truly necessary to change the idle speed; usually, people only do it to hide problems that they can't solve any other way.
mserge
Post12-12-2006, 13:24    Subject: Adjust idle speed Quote
I'm afraid I have to agree with you, but I only did it for testing purposes. icon_smile.gif
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts VW Polo 9N AWY - Rough idle; Adjust idle speed Gasoline Engine Technology
No new posts VAG-COM: Adjust Fuel Injection Amount Diesel Engine Technology
No new posts Modify STG 46 settings On-Board Diagnostics (OBD)
No new posts Automatic Shift Software: Change or Fix? Diesel Engine Technology
