Polo 9N: Driveshaft/CV Joint - Replacement Guide
Fröschi
Post16-01-2007, 0:46    Subject: Polo 9N: Driveshaft/CV Joint - Replacement Guide Quote
Hi everyone,
I have a question. I want to replace the wheel bearing housing on my girlfriend's Polo tomorrow (1.4 TDI, 75 hp, manufactured in December 2003, key number 2: 656).
"Can anyone tell me what size socket I need to replace the driveshaft nut? They always seem to come up with something new... It looks like a 36mm multi-spline socket, maybe? Any tips would be greatly appreciated."
Greetings,
Dirk.
Translated on 13-08-2026, 2:56.
Fröschi
Post16-01-2007, 11:23    Subject: Polo 9N: Driveshaft/CV Joint - Replacement Guide Quote
Okay, the axle nut is a 36-spline type. I just bought a new nut, and the trainee at ATU tried out different sockets. And the best part is, they didn't even have one that fit. They only had spline sockets up to size 32, and hex sockets up to size 48. But the size 36 hex socket was close in terms of size, except for the missing splines.
Maybe this will help someone else. I'll pick one up from my tool supplier later; it should cost around €12.
Dirk.
Translated on 13-08-2026, 2:57.
Post16-01-2007, 14:31    Subject: Polo 9N: Driveshaft/CV Joint - Replacement Guide Quote
HI.
I believe the engine should be an AMF or a B&S (Briggs & Stratton).
Can you please take a photo of this mysterious screw? icon_smile.gif Then we will all have learned something here.
Thank you.
Translated on 13-08-2026, 2:59.
Fröschi
Post16-01-2007, 15:08    Subject: Polo 9N: Driveshaft/CV Joint - Replacement Guide Quote
Sure, no problem.
Here is the picture.
http://www.mad-dogs-almerode.de/_sicherung/tmp/achsmutter.JPG
The largest diameter is 41mm and the smallest is 37mm. (These are approximate values; I will provide the exact measurements later when I have the nut.)
Has anyone ever seen a mother like that?
Greetings.
Translated on 13-08-2026, 3:00.
Post16-01-2007, 15:14    Subject: Polo 9N: Driveshaft/CV Joint - Replacement Guide Quote
Yes, it seems to be a standard 12-point [something].
You can also find this on the crankshaft, on the belt side, specifically the well-known crankshaft bolt that sometimes breaks off in older TDI engines.
http://home.arcor.de/sgrafen/salatoel/kw_schraube/kw_schraube.html
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts Polo 86c 40 kW, year 1992, 1272 ccm, AAV throttle potenti... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo combination instrument panel, 1998 to 09.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts QL Mount Motherboard: Secure & Easy Installation Transmission, Chassis, Body & Interior
No new posts G4 Driveshaft: Replacement & Parts Transmission, Chassis, Body & Interior
No new posts Drive shaft replacement: Is it covered? Diesel Engine Technology
No new posts Drive shaft removal Transmission, Chassis, Body & Interior
