tdi-seppl Blaumann
Joined: 02/01/2003 Posts: 44 Karma: +6 / -0 Location: Regensburg
17-05-2008, 9:37 Subject: High Water Temperature: Causes & Solutions |
"On my Audi 80 TDI with 90 horsepower and 290,000 km, the water temperature during normal driving is always around 100°C, often higher, and sometimes even reaches 110°C. The second stage of the radiator fan is almost always running. Previously, the operating temperature was always around 90°C, and it has gradually increased over the years. I assume the temperature gauge is accurate, because the thermostat switch activates the first stage of the radiator fan at approximately 95°C and the second stage at approximately 102°C. It's unlikely to be the thermostat of the water pump, because the radiator gets so hot that the thermostat switch in the radiator activates. The water pump was replaced about 2 years ago (without a thermostat). Could it be that the radiator is partially blocked (e.g., due to scale buildup)? Has anyone else experienced the same problem? I'm worried that this temperature will cause my "old car" to have a "heart attack"." Baust Du Turbo an Diesel,läuft Diesel wie Wiesel
Translated on 21-10-2026, 17:07.
teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
17-05-2008, 11:31 Subject: High Water Temperature: Causes & Solutions |
It sounds like you're saying: the engine's cooling system isn't working properly; the cooling capacity of the radiator is insufficient. Check the temperature. Add coolant or replace it. Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 21-10-2026, 17:08.
Profile PM Email Garage |
T3Surfer Profi-Schrauber
Joined: 09/17/2004 Posts: 1833 Karma: +34 / -0 Location: Frankurt 2001 Seat Toledo Premium Support
17-05-2008, 16:06 Subject: High Water Temperature: Causes & Solutions |
Often, even in vehicles with air conditioning, with this kind of mileage, the air conditioning condenser (radiator) and the water cooler become so heavily soiled that heat can hardly be dissipated. This is easily checked by loosening the condenser bracket and tilting it slightly forward to see if it's heavily soiled. This is especially common in vehicles that are frequently driven on high grass. If not, I agree with my predecessor. NA,Gehörlose wie ich können auch Schrauben! Ihr HÖRT ich FÜHLE! T3 TD EX-JX Jetzt 1Z mit 122PS und Renaultgetriebe Golf II TD Bj 84 512Tkm Passi 35I 1Z 468Tkm--> Seat Toledo AHF-- Toledo ARL 477Tkm mit Spritspartuning  99er T4 Syncro-Cross 100800km grad eingefahren
Translated on 21-10-2026, 17:09.
17-05-2008, 18:00 Subject: High Water Temperature: Causes & Solutions |
How about the heating capacity of the heating heat exchanger?
Should the temperature (approximate value) be measured at a minimum of 70°C?
At least at the medium blower setting.
the outside temperature.
fast engine speed,
Cooling water temperature: minimum 85°C.
If it's also cold, meaning 40-50 degrees Celsius, then rinse it.
If it's overheating, the engine radiator might be clogged internally or externally, as mentioned above. Gruß, der Teileklaus
Translated on 21-10-2026, 17:10.
tdi-seppl Blaumann
18-05-2008, 13:06 Subject: High Water Temperature: Causes & Solutions |
First of all, thank you very much for the answers.
I've decided to install a new cooler.
I don't think much of the radiator cleaner.
"The cooler costs €125 including shipping, and it's supposedly the same quality as the original."
I'll let you know if it really was the cooler.
Best regards, Baust Du Turbo an Diesel,läuft Diesel wie Wiesel
Translated on 21-10-2026, 17:11.
Kolbenring Blaumann
Joined: 09/09/2006 Posts: 35 Karma: +6 / -1 Location: Limburg
22-05-2008, 9:39 Subject: High Water Temperature: Causes & Solutions |
How was the problem resolved? Did the new cooler fix the issue?
Translated on 21-10-2026, 17:12.
tdi-seppl Blaumann
23-05-2008, 16:42 Subject: High Water Temperature: Causes & Solutions |
I installed a new water cooler today.
Now he has a normal temperature again.
The old one contained a brownish broth. Baust Du Turbo an Diesel,läuft Diesel wie Wiesel
23-05-2008, 16:55 Subject: High Water Temperature: Causes & Solutions |
I hope you flushed it with some cleaner. The rust-colored liquid can also get into the radiator! Gruß, der Teileklaus
Translated on 21-10-2026, 17:13.
Joined: 04/12/2002 Posts: 18144 Karma: +807 / -0 Location: St.Gallen 2018 Volkswagen T6
23-05-2008, 16:59 Subject: High Water Temperature: Causes & Solutions |
...and rinse it the other way, so that the sludge also comes out.
Profile PM WWW Garage |
