Boost Pressure Sensor: 250kPa Characteristics
Jochen_145
Post05-01-2007, 10:48    Subject: Boost Pressure Sensor: 250kPa Characteristics Quote
Hello everyone,
I am looking for the characteristic curve of the external 250 kPa boost pressure sensor for the ASV.
Unfortunately, the two parameters provided in Rainer's instructions for building a digital boost pressure gauge are not sufficient to test the sensor.
@Rudi or Rainer
What voltage/pressure characteristic curve is configured for this sensor in the MSG (Message) system?
Thank you for any help you can provide.
Best regards, Jochen.
Translated on 19-10-2026, 1:00.
Post05-01-2007, 10:51    Subject: Boost Pressure Sensor: 250kPa Characteristics Quote
Hello Jochen,
Since the initial characteristic curve of the sensor is a straight line, these 2 points are sufficient to determine all other operating points icon_wink.gif.
You can find the characteristic curve formula for the 250 kPa sensor, exemplified by model number 0273003210, here:
0273003210
Translated on 19-10-2026, 1:01.
Jochen_145
Post05-01-2007, 12:18    Subject: Boost Pressure Sensor: 250kPa Characteristics Quote
Well, yes, one should really read carefully.
My two-point sensor calibration was completely off, so I assumed that my sensor had a non-linear response curve.
If anyone else needs it for measurement tasks.
I've recalculated, and now the calculation is correct.
0.4V -> 20 kPa
4.65V -> 250 kPa
This leads to the following characteristic equation:
P_absolute
For those who prefer to see the relative charging pressure, the following equation is used:
P_LD
However, this is only valid under the assumption of an ambient pressure of 998 kPa.
@Rainer
I'm not sure if it's really necessary, but perhaps you could supplement the equations in your research paper.
Translated on 19-10-2026, 1:03.
No new posts P0236 - Turbocharger Overboost Condition - Bank 1 Sensor 'A' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Change Power Steering Assist Curve: Possible? Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Are Pierburg mass airflow sensors (MAF sensors) for DC an... Diesel Engine Technology
No new posts Throttle pedal characteristic curve, Fabia HTP, 3-cylinde... Gasoline Engine Technology
No new posts Boost Sensor in ECU? Diesel Engine Technology
