Boost Pressure Sensor: 250kPa Characteristics
Search
Automotive Technical Articles
Bookmarks
Links
Garage
Books / Tools
FAQ, Legal Notice & Privacy
RSS Feed
Register
Login
DE
EN
IT
New Topic
Reply
Dieselschrauber - Index
On-Board Diagnostics (OBD)
View previous topic
View next topic
Author
Message
Jochen_145
05-01-2007, 10:48
Subject: Boost Pressure Sensor: 250kPa Characteristics
Quote
Hello everyone,
I am looking for the characteristic curve of the external 250 kPa boost pressure sensor for the ASV.
Unfortunately, the two parameters provided in Rainer's instructions for building a digital boost pressure gauge are not sufficient to test the sensor.
@Rudi or Rainer
What voltage/pressure characteristic curve is configured for this sensor in the MSG (Message) system?
Thank you for any help you can provide.
Best regards, Jochen.
Translated on 19-10-2026, 1:00.
2018 Volkswagen T6
05-01-2007, 10:51
Quote
Hello Jochen,
Since the initial characteristic curve of the sensor is a straight line, these 2 points are sufficient to determine all other operating points
You can find the characteristic curve formula for the 250 kPa sensor, exemplified by model number 0273003210, here:
0273003210
Dipl.-Ing. (FH) Rainer Kaufmann -
Original VCDS mit KPower, KDataScope und Dieselschrauber Support
Translated on 19-10-2026, 1:01.
Profile
PM
WWW
Garage
Jochen_145
05-01-2007, 12:18
Quote
Well, yes, one should really read carefully.
My two-point sensor calibration was completely off, so I assumed that my sensor had a non-linear response curve.
If anyone else needs it for measurement tasks.
I've recalculated, and now the calculation is correct.
0.4V -> 20 kPa
4.65V -> 250 kPa
This leads to the following characteristic equation:
P_absolute
For those who prefer to see the relative charging pressure, the following equation is used:
P_LD
However, this is only valid under the assumption of an ambient pressure of 998 kPa.
@Rainer
I'm not sure if it's really necessary, but perhaps you could supplement the equations in your research paper.
Translated on 19-10-2026, 1:03.
New Topic
Reply
View previous topic
View next topic
Topic
Forum
P0236 - Turbocharger Overboost Condition - Bank 1 Sensor 'A'
Change Power Steering Assist Curve: Possible?
Are Pierburg mass airflow sensors (MAF sensors) for DC an...
Diesel Engine Technology
Throttle pedal characteristic curve, Fabia HTP, 3-cylinde...
Gasoline Engine Technology
Boost Sensor in ECU?
Select a forum
Diesel Motorentechnik
Benziner Motorentechnik
On-Board-Diagnose (OBD)
Dieselschrauber Bar
Allgemeine Tipps
KFZ-Technik-Artikel
Fehlersuche & Anleitungen
Technische Daten
Fachartikel
Weblogs
KFZ-Technik Quiz und Halden
Quiz
Upload
Schrotthalde
You
cannot
Kaufmann Automotive GmbH
Shop für Kfz-Diagnosegeräte
. Parse time: 0.076s
