Passenger Airbag: How to Reactivate It
Mati
Post12-05-2005, 0:16    Subject: Passenger Airbag: How to Reactivate It Quote
Does anyone have any further information on how to reactivate the passenger airbag using VAG-COM?
Audi Cabrio 2.0L, manufactured in 1994, engine code: ABK.
Sure, here's the translation:
'Thank you in advance!'
Mati.
Translated on 22-10-2026, 23:26.
hb2000
Post12-05-2005, 13:29    Subject: Passenger Airbag: How to Reactivate It Quote
It's best to have the workshop handle this, as they'll also need to assume responsibility for the warranty. It's likely the airbag was professionally deactivated, so the same qualified personnel should reverse the process. An entry should also be made in the vehicle's registration documents after the airbag is reactivated.
Translated on 22-10-2026, 23:27.
Mati
Post16-05-2005, 19:19    Subject: Passenger Airbag: How to Reactivate It Quote
Thank you for your contribution, however, you didn't read the question correctly.
I asked for more information.
I understand how the whole process is done professionally, but with this vehicle's production year, it probably won't be possible to adapt it for use with VAG COM.
Thank you again.
Greetings.
Mati.
hb2000
Post17-05-2005, 9:49    Subject: Passenger Airbag: How to Reactivate It Quote
Normally, a resistor is plugged into the airbag connector when the airbag is deactivated. This means the airbag is deactivated both mechanically and electronically. If you want to reactivate the airbag, you must first remove the resistor, then reconnect the airbag, and then use VAG-COM to reactivate the airbag in the control unit. However, please do not tamper with the airbag or the control unit yourself.
Translated on 22-10-2026, 23:28.
Mati
Post08-01-2007, 21:31    Subject: Passenger Airbag: How to Reactivate It Quote
I didn't know that the airbag had anything to do with the turn signal icon_wink.gif.
'Thank you for the information anyway.'
Greetings.
Mati.
Translated on 22-10-2026, 23:29.
Mati
Post09-01-2007, 22:21    Subject: Passenger Airbag: How to Reactivate It Quote
The post should not be here icon_redface.gif.
Greetings.
Mati.
No new posts Airbag-coding with VCDS **Introduction:** This document... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Aftermarket Leather Steering Wheel with Airbag Troubleshooting & Guides
No new posts Airbag Error 65535: A3 8L Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Airbag Activation: A4 1996 Model On-Board Diagnostics (OBD)
No new posts Passenger Door Electric Failure: Common Causes & Fixes On-Board Diagnostics (OBD)
No new posts Activate GRA: How to Enable & Use Diesel Engine Technology
No new posts Activate GRA in Audi A2 Diesel Engine Technology
