Car Key Programming (Immobilizer)
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
audidriver
Post05-01-2007, 13:26    Subject: Car Key Programming (Immobilizer) Quote
Hello, I've been trying for two days to fix something on my Seat Leon, manufactured in 2001.
I tried in vain to program the two remote keys to the control unit.
"First, the immobilizer and the comfort control unit were broken. I replaced them with new ones. I programmed the immobilizer following the instructions from openobd. However, the engine still won't start, or the immobilizer isn't disengaging. Can anyone tell me how to program the two keys? Or is there anything special I need to be aware of? It would be very helpful if someone could send me instructions on how to do it."
Translated on 18-10-2026, 12:28.
mullemaus
Post05-01-2007, 13:44    Subject: Car Key Programming (Immobilizer) Quote
Hi, the search function is your best friend. icon_wink.gif And then I can't quite understand what you want? Do you want to adjust the Wireless Frequency Settings (WFS) for both keys, or do you want to re-pair the remote control? There is a lot of material available for the WFS. icon_wink.gif
See the links in my post!
Translated on 18-10-2026, 12:29.
audidriver
Post08-01-2007, 18:19    Subject: Car Key Programming (Immobilizer) Quote
/viewtopic.php?t=13595&highlight=immobilizer
/viewtopic.php?t=11167&highlight=immobilizer
http://www.ross-tech.com/vag-com/cars/index.html
Okay, so here's the problem: the immobilizer can't be programmed. I've already tried all sorts of instructions. But the immobilizer just doesn't seem to work properly. It also keeps giving me a connection error when I try to log into the control unit with the 5-digit code icon_cry.gif. The 5-digit code is the one that came with it. I've also tried the one from the old immobilizer, but it doesn't accept that either. A friend says I absolutely need the 7-digit code. Could that be the case, and how do I get it? Because, according to the Seat dealership, they are the only ones who can provide it!
Translated on 18-10-2026, 12:31.
mullemaus
Post09-01-2007, 0:34    Subject: Car Key Programming (Immobilizer) Quote
If a connection is lost, the code is incorrect, or your VAG-COM version is shareware or not entirely 'legitimate'. icon_wink.gif What, or where, are you actually trying to program the WFS?
Translated on 18-10-2026, 12:32.
Ross-Tech-Support
Post09-01-2007, 3:17    Subject: Car Key Programming (Immobilizer) Quote
Mulle, only the former option is relevant. The shareware allows login without any problems. icon_smile.gif
audidriver, could you please provide us with a complete diagnostic report (a full vehicle scan)?
How did you train the WFS without code? Whether it's a 7-digit or 4-digit login doesn't matter, as long as it's correct. The 7-digit code is just an encrypted version of the 4-digit code.
audidriver
Post10-01-2007, 16:32    Subject: Car Key Programming (Immobilizer) Quote
Hello, I have the VAG Com 603.7 version with HEX and CAN from Dieselschrauber Shop. The 4-digit code was included with the new keys and the immobilizer. The reason I want to program the immobilizer is simple: the indicator light in the dashboard display doesn't turn off.
I then encountered the following error in memory 01176: "key not authorized," and then another error: "engine control unit not authorized." Which shareware are you referring to, and where can I get it?
Translated on 18-10-2026, 12:33.
Ross-Tech-Support
Post10-01-2007, 16:36    Subject: Car Key Programming (Immobilizer) Quote
I thought you might have a VAG-COM shareware.
Please provide us with a complete diagnostic report (auto-scan) and then tell us which instructions you are following to try and program the keys.
Translated on 18-10-2026, 12:34.
mullemaus
Post10-01-2007, 17:08    Subject: Car Key Programming (Immobilizer) Quote
Leon, model year 2001, is still running WFS II. Go to Control Unit -> Login -> MWB 21 and delete all the keys. Then, enter the number of new keys, save the changes. Next, go to Engine Control Unit -> Adaptation, Channel 0, and clear all the learning values. Finally, clear any error codes from both the instrument cluster (KI) and the engine control unit (MSG), and you're done.
Remember to include the zero before the four-digit number. So always use 0xxxx icon_wink.gif.
Translated on 18-10-2026, 12:35.
Ross-Tech-Support
Post10-01-2007, 18:18    Subject: Car Key Programming (Immobilizer) Quote
mullemaus wrote:
The Leon, model year 2001, is still running WFS II.
You are mistaken. WFS-III was introduced in the Leon/Toledo (1M) model with the model year 2002, and as you know, this began on May 1, 2001. Therefore, a 2001 model year could very well be either WFS-II or WFS-III, although WFS-III is more likely.
That's why I'm also explicitly asking about the diagnostic protocol (auto-scan).
Translated on 18-10-2026, 12:36.
mullemaus
Post10-01-2007, 19:08    Subject: Car Key Programming (Immobilizer) Quote
The Leon Bj 2001 is still running WFS II.
You're wrong. WFS-III was introduced in the Leon/Toledo (1M) model with the 2002 model year, and as you know, that started on May 1, 2001. Therefore, a 2001 model year could very well be either WFS-II or WFS-III, although WFS-III is more likely.
Therefore, the explicit question about the diagnostic protocol (auto-scan).
Then, of course, he needs to be trained on WFS III. icon_wink.gif But with limited information, an accurate fault diagnosis is also not possible. icon_wink.gif
Translated on 18-10-2026, 12:37.
audidriver
Post16-01-2007, 10:14    Subject: Car Key Programming (Immobilizer) Quote
Hello, I've already tried using WFS II, but unfortunately, it didn't work either.
Here's the protocol for everyone.
Saturday, January 13, 2007, 2:19:17 PM.
VAG-COM Version: RKS 607.3-UD
Vehicle type: 1M - Seat Leon/Toledo.
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
Chassis number: XXXXXXXXXXXXXXXXX
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BÀume, und die BlÀtter rascheln leise. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen."
Address 01: Engine.
Part number: 036 906 034 CP
Component: MARELLI 4MV, 3956.
Encoding: 00031
Workshop code: WSC 00000
VSSZZZ1MZ2R068318 SEZ7Z0A1413661
2 errors found.
17978 - Engine control unit locked.
P1570 - 35-00 - -
18058 - Data bus drive: missing message from the instrument cluster.
P1650 - 35-10 - - - Intermittent.
Self-test: 1110 0101
Address 03: ABS Brakes.
Part number: 1C0 907 379 J
Component: ABS FRONT MK60 0103
Encoding: 0001025
Workshop code: WSC 00001.
"One error found:"
01314 - Engine Control Unit.
004 - No signal/communication - Intermittent.
Address 15: Airbag.
Part number: 1C0 909 605 A
Component: 1L AIRBAG VW51 0A 0004
Encoding: 12620
Workshop code: WSC 06441.
"One error found:"
01299 - Diagnostic interface for data bus (J533)
49-10 - No communication - Intermittent.
Address 17: Combination instrument.
Part number: 1M0 920 822 AV
Component: KOMBI+WEGFAHRSP VDO V06
Encoding: 04102
XXXXXXXXXXXXXXXXX SEZ7Z0E2978319
2 errors found.
01176 - Key
65-10 - unauthorized - occasional.
01177 - Engine Control Unit.
Address 19: CAN Gateway.
Part number: 6N0 909 901.
Component: Gateway K<->CAN 0001
Encoding: 00006
No errors found.
Address 46: Comfort System.
Part number: 1C0 959 799 E
Component: 2U Comfort Device HLO 0003.
Encoding: 00067
Part number: 1C1959801A
Component: 2U Tor Control Unit, FS KLO 0002.
Part number: 1C1959802A
Component: 2U Tor Control Unit, BF KLO 0004.
No errors found.
"End"
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Perhaps someone knows more now.
Translated on 18-10-2026, 12:45.
Ross-Tech-Support
Post16-01-2007, 10:29    Subject: Car Key Programming (Immobilizer) Quote
audidriver wrote:
Hi, I've already tried using WFS II, but unfortunately, it didn't work.
Logically, this is because the vehicle is equipped with WFS-III, and the instrument cluster has not yet received the vehicle identification number from the engine control unit.
audidriver wrote:
Address 01: Engine.
Encoding: 00031
2 errors found.
P1570 - 35-00 - -
We therefore assume that the engine control unit still contains the original vehicle identification number (VIN) and immobilizer identification (WFS.ID). Is the PIN (secret code for working on the immobilizer) for the vehicle or engine control unit known? If so, what happens when you log in to the engine control unit using this PIN (VAG-COM > Selection > 01 - Engine > Login - 11)? Pay attention to the small gear in the upper left corner; does it rotate smoothly, or is the connection interrupted?
Encoding: 04102
2 errors found.
01176 - Key
65-10 - not authorized - Sporadically
The instrument cluster is a brand new part, meaning it has never been connected to a vehicle before. Is the PIN (security code for accessing the instrument cluster) known for this new instrument cluster? If so, what happens when you log in to the instrument cluster using this PIN (VAG-COM > Selection > 17 - Instrument Cluster > Login - 11)? Pay attention to the small wheel in the upper left corner; does it rotate smoothly, or does the connection drop?
audidriver wrote:
Maybe someone knows more now.
Translated on 18-10-2026, 12:54.
audidriver
Post16-01-2007, 12:00    Subject: Car Key Programming (Immobilizer) Quote
A 5-digit PIN was included with the keys. When I try to log in using this PIN in the instrument cluster, it takes a while, and then the connection is interrupted. Or is this the wrong PIN that came with the keys? I'm now trying to log in to the engine control unit. Where can you get a new PIN if the one you have is incorrect?
Translated on 18-10-2026, 12:58.
Ross-Tech-Support
Post16-01-2007, 12:04    Subject: Car Key Programming (Immobilizer) Quote
audidriver wrote:
A 5-digit PIN and the corresponding keys were included with mine.
It is NEVER a 5-digit login printed on a keychain. The number you are referring to is the key number, and it has nothing to do with the immobilizer system.
audidriver wrote:
Where does one actually get a new PIN if the current one is incorrect?
A Seat dealer can technically obtain both PINs for you via fax.
Okay, first of all, your problem is the missing or incorrect PINs - then we can look at other things. icon_smile.gif
Translated on 18-10-2026, 12:59.
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Programming keys Diesel Engine Technology
No new posts Immobilizer 1H0 953 257 B: Reprogramming & Replacement On-Board Diagnostics (OBD)
No new posts New Car Key / Immobilizer Replacement On-Board Diagnostics (OBD)
No new posts Skoda Roomster: Key Programming (Immobilizer) On-Board Diagnostics (OBD)
