@Rudi
Okay, so I can't simply determine the air mass by directly tapping into the sensor and using a two-point calibration in the logger.
Well, then I have to resort to offline calculations, and I will log the transmitted voltage of the MAF (Mass Air Flow) sensor.
@Devil
I'm now strongly assuming that a 5V short circuit at the sensor after power-up would indicate an error and you would receive an error message.
Often, the initial voltages of 0V and 5V (or 12V, which is in any case the maximum sensor supply voltage that is theoretically available as an output voltage) are not used to enable a sensor diagnosis.
You also get 0V if the sensor hasn't been installed, which means you can't tell whether it's a minimum reading or a missing sensor. Therefore, it's often started at 0.5V = minimum reading (or another voltage other than 0V).
You also have a 5V reading (or sensor supply voltage) if the sensor shorts out and is defective –> therefore, you still can't determine whether it's a maximum value or a faulty sensor. With a 5V sensor, you often end up with a maximum measured value of 4.5V.
If you use a sensor that is not used for fault monitoring (e.g., additional sensors), you still have the entire supply voltage range as a signal output, unlike what was described above. However, there is no way to diagnose the connected sensor.
In the LLM simulation, the diode will output a sensor value of either 4.5V or 4.3V, which would correspond to the maximum (or nearly maximum) measurement range, but it wouldn't represent a short circuit for diagnostic purposes.
Best regards, Jochen.
[/edit] Oops, I wrote too much, and Ulf said the same thing in fewer words and much faster. Now you've heard it from two sides...
