Climatronic Error Code 313: Troubleshooting Guide
rl2664
Post30-11-2002, 19:32    Subject: Climatronic Error Code 313: Troubleshooting Guide Quote
While this might be a bit off-topic, I hope someone here knows the answer.
I'm having a problem with the outside temperature display on my Audi/Volkswagen Passat. It occasionally shows a temperature that is too low. Usually, after a few minutes, the display corrects itself and shows the correct value.
Okay, I just replaced the external temperature sensor [1], but the symptoms have only changed in that it still occasionally displays too low a temperature, but the value no longer increases; instead, it immediately jumps to the correct temperature.
Does anyone have anything to say about this?
Thank you in advance.
Ronny.
[1] The prices at VW are completely crazy. An outside temperature sensor for my 1998 Passat 3B costs about 54 EUR. I bought one for a 2001 3BG, and it only costs 2.48 EUR! Okay, for the 1998 model, you get the sensor with the cable, but for the 2001 model, you only get the sensor. But that's not a big deal; the soldering iron is your friend.
I find it quite outrageous to charge 52 euros for a piece of cable that's only half a meter long.
Translated on 18-09-2026, 10:01.
No new posts Error code Climatronic 3B, model year 1999, 2000 model Troubleshooting & Guides
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts Climatronic Error: Doku Sharan 7M8 Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Climatronic Error Codes: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Climatronic Error Code 04F7: Diagnosis & Troubleshooting On-Board Diagnostics (OBD)
No new posts Climatronic G3 TDI Transmission, Chassis, Body & Interior
No new posts Log Climatronic Upload
