AGR Rate Guide: How to Calculate & Optimize
NorthstarV8
Post09-05-2007, 20:50    Subject: AGR Rate Guide: How to Calculate & Optimize Quote
I have a Fabia RS (BLT) that's experiencing the common issue of engine misfires due to the AGR system. I spoke with my workshop about adjusting the mass airflow sensor (MAF) target value. They contacted Skoda, but apparently, they are not familiar with either the misfire issue or any adjustments related to it. So, my question is: Does anyone have a Skoda or VW (Polo) instruction manual regarding this adaptation, or a contact person at Skoda? If so, I can provide it to my workshop.
Thank you in advance.
Translated on 24-09-2026, 1:55.
No new posts VAG-COM sampling rate Diesel Engine Technology
No new posts VW AGR Tester Rate On-Board Diagnostics (OBD)
No new posts AGR-Rate im leerlauf On-Board Diagnostics (OBD)
No new posts Correlation between AGR rate and noise Diesel Engine Technology
