Webasto Thermo Top C
tevier
Post15-01-2007, 18:54    Subject: Webasto Thermo Top C Quote
Hi, I have a Webasto Thermo Top C, manufactured in 2004. Now I have the problem that it no longer starts. Two weeks ago it was running perfectly, and suddenly it only starts the burner fan and the circulation pump when switched on. I have cleaned the combustion chamber and tested the dosing pump. Everything seems to be okay. I wanted to have the error memory read out at a workshop, but the technician said that it is impossible to read it out because the control unit is not responding. I would be grateful if someone could help me. (maybe Flammwächter/Glühstift ?)
austrogolf
tevier likes this.
Post15-01-2007, 19:18    Subject: Webasto Thermo Top C Quote
hello,
also had the same problems with my TT-C (diesel). however, I was able to read the error codes. and this also confirmed the suspicion of a glow plug issue.
After that, I wanted to arrange the purchase of the glow plug myself from a Webasto dealer; however, they only wanted to sell the entire combustion chamber. Afterwards, I bought the glow plug from a VW dealer (since VW buses also have the TT installed).
greetings.
tevier
Post15-01-2007, 19:53    Subject: Webasto Thermo Top C Quote
Thank you for the super quick response. I think I'll try to get a glow stick. If that's the case, I will report it here.
I really don't hope for a faulty control unit.
tevier
Post11-02-2007, 14:29    Subject: Webasto Thermo Top C Quote
I haven't been successful with the multimeter icon_cry.gif, but I have now found the fault. icon_biggrin.gif There is a loose connection on the control unit. When I remove the screws of the control unit cover, everything works as it should, but as soon as I tighten the cover, the heater stops. A little tinkering, a little adjustment (capacitors), and now it's even running again with the lid securely fastened.
No new posts Webasto Heater Diagnosis: Retrofit Systems Troubleshooting & Guides
No new posts Webasto Thermo Top with CAN Bus: Installation & Guide Transmission, Chassis, Body & Interior
No new posts Webasto Thermo Top: Outside temperature sensor Transmission, Chassis, Body & Interior
No new posts Standheizung Webasto Thermo Top Diesel Engine Technology
No new posts Webasto Thermo Top E for Golf III TDI with Climatronic Transmission, Chassis, Body & Interior
