LLM Tuning: Optimize Your Language Model
DaBibo
Post29-04-2003, 18:18    Subject: LLM Tuning: Optimize Your Language Model Quote
I have a question...
The LMM (likely referring to a mass airflow sensor) is housed in a casing through which air flows. If you force more air over the measuring film by using a kind of funnel, wouldn't that increase the performance or improve the readings?
Translated on 15-10-2026, 19:07.
donalexo
Post29-04-2003, 19:37    Subject: LLM Tuning: Optimize Your Language Model Quote
Hello DaBibo!
The conceptual approach isn't bad at all! If you narrow the cross-section to such an extent that the flow velocity in the measurement section is increased by the percentage decrease in the LMM measurement signal, then a compensation effect is achieved.
For nearly incompressible media, such as liquids, the required cross-sectional area can be easily determined using the continuity equation.
In the case of a gas, the laws of gas dynamics must also be taken into account, but I believe that throttling through a moderate reduction in cross-sectional area will likely have a negligible effect.
However, a prerequisite for such compensation would be a uniform decrease in the LMM signal across the entire speed range, i.e., a parallel shift of the characteristic curve.
IMO, with a faulty mass airflow sensor (MAF), the characteristic curve is more likely to be "stepped," meaning that it deviates from the expected curve only above a certain engine speed.
This, at least, is what my measurement from yesterday showed, using my faulty MAF sensor (see the post "MAF sensor statistics"). Please correct me if I'm wrong!
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 15-10-2026, 19:09.
00schmu
Post29-04-2003, 21:34    Subject: LLM Tuning: Optimize Your Language Model Quote
I once reversed my LMM (likely referring to a Large Language Model) so that the airflow went in the wrong direction.
Subjectively, it performed better.
Translated on 15-10-2026, 19:10.
matt
Post04-03-2007, 14:47    Subject: LLM Tuning: Optimize Your Language Model Quote
Are there more experiences available regarding incorrectly installed LMMs, especially measurement data?
Best regards, Matthias.
Translated on 15-10-2026, 19:11.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts Euro 4 requirement not as "absolute" as previously thought? Diesel Engine Technology
No new posts Injector Nozzles: Can You Repair the "Tips"? Diesel Engine Technology
No new posts RNS315 Upgrade: Install "Discover Media" Now! Electrical Systems, Vehicle Electronics, Multimedia
