For a standard car radio with an ISO connector, connect to pin 1. Wire color: white/blue. At the instrument cluster, on the green 32-pin connector, connect to pin 30. Wire color: white/blue.
Or even more complicated.
In the engine compartment, on the splash guard on the driver's side. Directly below the windshield, near the water reservoir in the clutch station's electrical box. Brown connector. Wire color: white/blue. Gruß Bertil
Translated on 25-10-2026, 0:25.
