Whining transmission on A4 2.5 TDI, 12/99
Warning: Trying to access array offset on false in /var/www/community/attach_mod/includes/functions_filetypes.php on line 58
kottan-ermittelt
Post16-01-2007, 10:30    Subject: Whining transmission on A4 2.5 TDI, 12/99 Quote
Hello.
'Recently, my A4's transmission (2.5 TDI, 12/99, 150,000 km) has been making a howling noise.' It's not audible during acceleration or when driving at a constant speed, but only when releasing the gas pedal, specifically when the clutch is engaged, and starting around 90 km/h.
What could be the cause? How do I get a diagnosis?
Thank you for any advice!
Steffen.
kottan-ermittelt
Post16-01-2007, 15:01    Subject: Whining transmission on A4 2.5 TDI, 12/99 Quote
That's probably what they call 'putting things off.'
BM
Avatar-BM
Post16-01-2007, 17:35    Subject: Whining transmission on A4 2.5 TDI, 12/99 Quote
By first providing useful information icon_exclaim.gif.
- Automatic / Manual transmission? Gearbox identification code?
- In which gear does the noise occur?
- temperature-dependent?
- Description of the sound.
- Is the transmission leaking oil, or is the oil level okay?
- etc.
3B5 AJM
kottan-ermittelt
Post16-01-2007, 19:02    Subject: Whining transmission on A4 2.5 TDI, 12/99 Quote
I am trying to be more precise icon_wink.gif.
- 6-speed manual transmission, transmission code DQS.
- In which stage of the process does the noise occur: 4, 5, and 6?
- equally effective with a cold engine and a warm engine.
- is definitely a high-frequency sound, singing.
- The transmission is not leaking any oil, and the oil level is okay.
- The transmission oil was changed yesterday - no change.
kottan-ermittelt
Post16-01-2007, 23:27    Subject: Whining transmission on A4 2.5 TDI, 12/99 Quote
I recorded it with my phone, it's a load change in 4th gear, between 2000 and 3000 rpm. Unfortunately, I can't upload it as an MP3, so I renamed the file from 'sound.mp3' to 'sound.jpg'.
 von sound.mp3 nach sound.jpg umbenannt
 File size:  339.75 KB
 Viewed:  3644 times
Herr Antje
Post17-01-2007, 8:09    Subject: Whining transmission on A4 2.5 TDI, 12/99 Quote
I'm guessing it's either the transmission (specifically, the clutch) or the differential. For both, the transmission needs to be removed, so I'll start by seeing if you can get any other advice. Unfortunately, I don't have any icon_sad.gif.
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
R.M.
Karma: +14 / -0   Thank you, like it!
Post20-01-2007, 11:30    Subject: Whining transmission on A4 2.5 TDI, 12/99 Quote
"Also, I also had a differential issue on my 35i. After a drive, check the transmission where the driveshafts come out, or the driveshafts themselves." One of the drives was cold (normal), while the other was extremely hot.
Hi!
kottan-ermittelt
Post15-02-2007, 14:48    Subject: Whining transmission on A4 2.5 TDI, 12/99 Quote
It was a bearing in the transmission. I had it fixed for 1000 [currency]. Thank you for the tips!
Helau.
Herr Antje
Post15-02-2007, 14:57    Subject: Whining transmission on A4 2.5 TDI, 12/99 Quote
Thank you for the feedback. Hopefully, you'll have some peace and quiet for a while now.
I had it made for 1000.
Only the stock items, or all items? Does the price include installation and removal?
Aktuell:
kottan-ermittelt
Post27-02-2007, 10:48    Subject: Whining transmission on A4 2.5 TDI, 12/99 Quote
'1000 for everything, including installation and removal. I don't know if all the bearings were replaced or just the defective one. In any case, all the wheels had to be removed from the shaft (they had to be shrunk-fitted), which was quite complicated. It was done by a professional, and it's working perfectly again.'
No new posts Document LT 28, Transmission Noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Touareg, Transmission in Emergency Mode Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A2 to A6, Gearbox Area, Customer Goodwill Policy Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR EGT Sensor for Audi A6 2.5 TDI Diesel Engine Technology
No new posts OT Markierungen beim Audi A6 2.5TDI ??? Diesel Engine Technology
No new posts Verschlissene Nockenwellen beim V6 2.5TDI Diesel Engine Technology
No new posts Einspritzdüsen ausbauen beim V6 2.5TDI Diesel Engine Technology
