Help with error code
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Joschis
Post01-03-2007, 19:18    Subject: Help with error code Quote
Hello everyone,
I have the following error.
T4 Bus 2.5L TDI (ACV)
Error code: 16885.
Vehicle speed signal: implausible signal.
Possible causes.
No signal from the speed sensor (G22).
The speedometer isn't working, but the tachometer and everything else is fine.
Thank you for the help in advance.
VW Passat V6 TDI 2,5
Bj. 10.1999 / AFB
bloesch
Post01-03-2007, 19:24    Subject: Help with error code Quote
Look at the back of the gearbox from below, meaning from back to front.
Then you should see one sensor on the right and one on the left of the transmission. icon_wink.gif Critters often get into them and chew on the wires.
Joschis
Post01-03-2007, 19:37    Subject: Help with error code Quote
Okay, I'll take a look.
Okay, I forgot to mention that it's a T4 with a 2.5L TDI engine (ACV).
Is that exactly the same?
Bj. 10.1999 / AFB
bloesch
Post01-03-2007, 20:09    Subject: Help with error code Quote
Oops... I was basing my assumptions on the Passat V6 TDI.
If I understand correctly, the T4 transmission has two sensors, one on the side and one on top... it must be the one on top. (Part number: 095 927 321c?)
It's a bit surprising, though, that the DZM is still working.
Joschis
Post01-03-2007, 20:17    Subject: Help with error code Quote
The sensor with the number 095 927 321 C is a speed sensor.
I'll take a look and see if the cable is disconnected.
Do you have any other ideas about what it could be?
Thank you for the helpful tip.
Bj. 10.1999 / AFB
No new posts Error code P1351 General Tips
No new posts Error code 01276 - ABS hydraulic pump (V64) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ESP function test, error code 01486 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat mit 1Z springt schlecht an, kein Fehlercode, Hilfe Diesel Engine Technology
No new posts Hilfe, Hilfe Schlechter Durchzug beim 150 PS TDI Diesel Engine Technology
No new posts Fehlercode 2.5 tdi, AAT u.ä. Diesel Engine Technology
No new posts Error code Diesel Engine Technology
