danko wrote: |
Hello dear community!
My actual question is whether a more experienced DIYer like myself can successfully replace the hydraulic lifters.
2) What should be particularly considered when making the exchange, and what are the pitfalls of undertaking this endeavor?
3) Is it better to replace all 8 lifters, or should I put in the effort to pinpoint the supposedly defective ones?
1) Yes, you can probably do it yourself, assuming I can even assess your skills... I would get a good repair manual, for example from Erwin.
2) If you follow the instructions carefully. Pay attention to the order in which you loosen and tighten the NW flange halves, and remember the order and orientation in which they are installed. They must be reinstalled in the same way.
3) All 8 (you're lucky, I had 12 (G3) or 24 (3BG)
). The others might also break soon, and since you're already doing the work...
"Please be careful and don't just buy the cheapest options from online marketplaces. Opt for a reputable brand like INA or FEBI. Also, make sure to buy from a retailer where you can be certain that you're getting the brand that's actually printed on the packaging. I've been tricked before..."
