Passat MSG Swap: '99 AFN to '97 AFN
Nash
1997 Volkswagen Passat
Post14-03-2007, 19:52    Subject: Passat MSG Swap: '99 AFN to '97 AFN Quote
Hello fellow mechanics!
I plan to replace my MSG (1) with the following (2).
1.
VW Part No.: 028 906 021 GL
Bosch Part Number: 0 281 001 656
Data as of: 1446.
Date: June 21, 1997.
2.
VW Part No.: 038 906 018 GA
Bosch Part Number: 0 281 010 170
Data as of: 2605.
Date: 04/27/99
Okay, those are the basic specifications for now. I'm aware that the swap might require other hardware changes, and I've already planned for those and have almost everything I need.
The last hurdle for me now is whether my "older" AFN will work with the "newer" software, or if there will be any issues. Although, the engines themselves haven't really changed much.
Unfortunately, I lack the sources needed for this.
And that's why I'm asking my question here.
Nash.
AFN mit aktuell 546.465km auf der Uhr
Translated on 28-10-2026, 22:37.
Rudi
Post14-03-2007, 21:43    Subject: Passat MSG Swap: '99 AFN to '97 AFN Quote
Why do you even want to trade?
The hardware of the two control units is identical, except for the connectors, which would require modifications.
Require cable trees - nearly identical.
Rudi
Translated on 28-10-2026, 22:39.
Nash
Post15-03-2007, 16:34    Subject: Passat MSG Swap: '99 AFN to '97 AFN Quote
Because the new MSG controller has CAN functionality, I can also install a 920 speedometer in it.
Rudi
Post15-03-2007, 18:29    Subject: Passat MSG Swap: '99 AFN to '97 AFN Quote
To operate CAN tachometers in cars without a CAN bus, there are, as far as I know, ready-made solutions available.
Adapters that convert the corresponding signals to CAN.
Rudi
Translated on 28-10-2026, 22:40.
Nash
Post15-03-2007, 19:08    Subject: Passat MSG Swap: '99 AFN to '97 AFN Quote
But how does the whole WFS thing work then? Because it probably isn't possible to downgrade from generation 3 to 1. And I really wanted to keep all of that.
Or is this a newer adapter that I'm not yet familiar with?
Rudi
Post15-03-2007, 19:41    Subject: Passat MSG Swap: '99 AFN to '97 AFN Quote
WFS geht bei den ollen Gurken in jedem Fall über K-Line. Even...
The subsequent generation of MSTGs (EDC15) continued to communicate primarily via K-Line for quite some time.
Rudi
Translated on 28-10-2026, 22:41.
Nash
Post15-03-2007, 20:17    Subject: Passat MSG Swap: '99 AFN to '97 AFN Quote
Well, the issue isn't really with the K-Line.
What I mean is, if I install a WFS3 AI unit with the CAN adapter, will it definitely not be possible to connect it to my WFS1 messaging system, or are there things I don't know about yet?
And I don't want to turn it off or bypass it.
Rudi
Post15-03-2007, 20:31    Subject: Passat MSG Swap: '99 AFN to '97 AFN Quote
Are you sure that the 018GA was installed with a WFS3 AI unit?
Translated on 28-10-2026, 22:42.
Nash
Post15-03-2007, 20:40    Subject: Passat MSG Swap: '99 AFN to '97 AFN Quote
I know that the 018 GA is a WFS2-MSG, but it is certainly possible to connect a WFS3-Ki to it.
I'm also certain that the new control unit (Ki) cannot be linked to my current main system (WFS1), which is why I'm doing the conversion.
Rudi
Post15-03-2007, 20:46    Subject: Passat MSG Swap: '99 AFN to '97 AFN Quote
... but it is certainly possible to train a WFS3-AI on it.
Good luck!
Alternatively, you could install a separate WFS control unit, such as the one used in the Golf 3.
Translated on 28-10-2026, 22:43.
No new posts Glow Plug Module Replacement - Workshop Special Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Swap seat with side airbag for a Recaro seat Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the climate control actuator motors in an Audi ... Troubleshooting & Guides
No new posts ATF change for A6 TDI AKE Diesel Engine Technology
No new posts ABS Sensor Replacement: G3 Guide & Tutorial Transmission, Chassis, Body & Interior
No new posts MFA for FIS swap On-Board Diagnostics (OBD)
No new posts Fuel Injectors AFN: Replacement Guide Diesel Engine Technology
