Read Email: Extracting Messages Easily
Burli
Post24-03-2007, 19:36    Subject: Read Email: Extracting Messages Easily Quote
Technical specifications:
Passat 35i, 1.9 TDI, engine code: 1Z, year of manufacture: 1995.
I have this MAS motherboard here that had other chips installed in the past, and in the process, the traces were damaged by my predecessor. I have now fixed this issue.
Now, I wanted to read out the MSG (Modular Signaling Gateway) using VAG-Com, but I don't want to have to replace the MSG in the car every time.
My question:
Do I need to connect to the L-line of the OBD socket to read the data, since I can't find that pin on the MSG (Modular Service Interface)? I'm not getting a connection even though I've connected the various positive and ground pins, and PIN 61 as the K-line. Or do I have to physically install the 'bucket' (presumably a device) in the car?
Thank you very much.
Burli.
Translated on 11-10-2026, 15:27.
Rudi
Post24-03-2007, 19:58    Subject: Read Email: Extracting Messages Easily Quote
A plus, a ground, and a K-Line (61) are sufficient.
If communication fails at that point, then there's likely something wrong with the MSTG.
On behalf of.
'A '95 Passat might still be scrap metal (MSA12). Especially if friends are getting rid of theirs.'
I'd like to arrange some cross-border communications. Also, I'm not a fan of that.
Flat ribbon cable between the circuit boards, no movement.
Rudi
Translated on 11-10-2026, 15:29.
Burli
Post24-03-2007, 20:00    Subject: Read Email: Extracting Messages Easily Quote
Thank you for the quick response.
Which pin do you connect to the positive (+) and which to the ground (GND)?
Have a nice weekend.
Burli.
Translated on 11-10-2026, 15:30.
Rudi
Post24-03-2007, 20:07    Subject: Read Email: Extracting Messages Easily Quote
1: Mass
23: 12V
Translated on 11-10-2026, 15:31.
No new posts Read CAN Bus with Microcontroller On-Board Diagnostics (OBD)
No new posts How to Read: A Beginner's Guide On-Board Diagnostics (OBD)
No new posts Read ash data On-Board Diagnostics (OBD)
No new posts Read Error Codes: How To & Troubleshooting On-Board Diagnostics (OBD)
