Oval Gear Spanner Element Belt
herold4
Karma: +4 / -1   Thank you, like it!
Post29-08-2007, 21:04    Subject: Oval Gear Spanner Element Belt Quote
Hello, I was wondering if anyone has a technical explanation for the "oval gear-sprocket chain"? I have read that this is a "Contitech" development and in the
Newer pump-nozzle engines are now available for use. Here, one writes that these belts {BELT_TYPE}
should be able to last up to 250,000 Km.
The function of the oval gear span element is still unclear to me, and I haven't found much information about it.
Can anyone help, maybe even a link?
tdi pumpe düse
Post29-08-2007, 21:33    Subject: Oval Gear Spanner Element Belt Quote
Here's something to read.
Ovales Zahnriemenrad.pdf
 File name:  Ovales Zahnriemenrad.pdf
 File size:  84.09 KB
 Downloaded:  1424 times
No new posts Documentary: Transporter 7D, Timing belt failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt Issue: A3 (98+) - Not Centered on ESP Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BMR Expansion Joint: Types & Applications Diesel Engine Technology
No new posts Timing belt component, notched belt, broken. Cause? Diesel Engine Technology
No new posts Zahnriemen Diesel Engine Technology
No new posts Timing Belt AJM Diesel Engine Technology
