Coding Golf4 TDI all-wheel drive and 2WD in the engine control unit?
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post29-03-2007, 12:15    Subject: Coding Golf4 TDI all-wheel drive and 2WD in the engine control unit? Quote
Hello.
I am interested in the following:
What changes when I recode the engine control unit from all-wheel drive (AWD) to two-wheel drive (2WD)? The all-wheel drive system (Haldex) is still controlled normally with the 2WD coding, and no error codes are written to the control unit. Could it be that this affects the ABS, ESP, etc.? Although, the braking control unit is also coded for all-wheel drive?
Thank you very much for your suggestions.
Best regards.
Thomas.
Audi SQ5 8R Cvub
Translated on 10-07-2026, 4:43.
Back to top Profile PM Email
No new posts Turbocharger Boost Control Problem - Golf4 AXR Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Quietschen Vorderachse links (Golf4) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf4: Turn signals flickering, wipers too slow, lights t... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Codierung Tacho Golf4 nicht änderbar! On-Board Diagnostics (OBD)
No new posts Engine Control Unit (ECU) Coding 0002/0012 On-Board Diagnostics (OBD)
No new posts Motorsteuergerät verliert Codierung der Wegfahrsperre.... On-Board Diagnostics (OBD)
No new posts Coding and Coding II disabled after software update On-Board Diagnostics (OBD)
