Incorrect injection timing suddenly occurred.
MWeid
Post31-03-2007, 20:19    Subject: Incorrect injection timing suddenly occurred. Quote
Hello, fellow diesel enthusiast!
The 1Z (with the new KW screw) of a friend suddenly stopped working (overnight) and would only start with a lot of smoke (and starting fluid). Since we disconnected the coolant temperature sensor, the engine has improved (without a start pilot), and we were finally able to start the engine - although it was running poorly.
In the memory, the injection start time was stored, which we have now corrected by turning the fuel pump 'later'. We have turned the ESP 5mm 'earlier', which I find quite extreme. Now the engine is running smoothly again.
But the underlying cause hasn't been fixed, and I don't want to take any chances. What I noticed in comparison to my 1Z is: The timing belt pulley deflects approximately 4mm 'tip-to-tip' (I'm an automotive technician icon_wink.gif). Does this indicate a worn (despite being 'new') crankshaft? What else can we check? What do you think about the 5mm 'misalignment'? Is it possible that the timing belt has snapped around a tooth?
I know that 5mm is a very precise specification for a rotation icon_wink.gif. I will provide an image showing where the 5mm is measured.
I have tried searching, but I couldn't find anything. If this topic has already been discussed in other threads, please provide a link or keywords that I can use to search the search engine.
Regarding the vehicle: VW Golf Variant, 1Z, Year of Manufacture: 1994, 224,000 km, the last timing belt replacement was two years and approximately 30,000 km ago.
Thank you and best regards,
Mathias
christians
Post31-03-2007, 21:14    Subject: Incorrect injection timing suddenly occurred. Quote
If the stub was already rounded off, a new screw won't help. However, it is also possible that the ZR jumped over.
Gruß Christian
MWeid
Post31-03-2007, 22:34    Subject: Incorrect injection timing suddenly occurred. Quote
I expressed myself incorrectly, I meant: He already has the 'permanent' KW screw.
EDIT: Either from the factory or it was replaced during the first ZR change. Would a missed deadline have a more significant impact?
Post01-04-2007, 8:34    Subject: Incorrect injection timing suddenly occurred. Quote
Yes, that would be a gamble... continuing to drive the car without at least taking a good look at the KW wheels.
Karma: +642 / -0   Thank you, like it!
Post01-04-2007, 8:38    Subject: Incorrect injection timing suddenly occurred. Quote
Definitely, before the next engine start, remove the timing belt and check what's wrong.
Mephisto
Karma: +14 / -1   Thank you, like it!
Post02-04-2007, 13:04    Subject: Incorrect injection timing suddenly occurred. Quote
and if then only with a lot of smoke (and starter fuel)
Startpilot beim Diesel? Do you already know what you're doing?
Greetings
Micha
Gremlin
Avatar-Gremlin
Karma: +91 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
Post02-04-2007, 18:45    Subject: Incorrect injection timing suddenly occurred. Quote
The pulley's center distance is approximately 4mm "tip-to-tip"
Please do not attempt to start the engine again. It is best to remove the KW coilover, re-plan the strut, and install a new strut with a new bolt. Torque to 90 Nm + 90 degrees (Not guaranteed). Everything else is Russian Roulette.
Greetings
MWeid
Post03-04-2007, 15:45    Subject: Incorrect injection timing suddenly occurred. Quote
It wasn't my idea. The guys wanted to get the donkey running again, and apparently, they were willing to do anything to achieve that... icon_rolleyes.gif
I will definitely tell the mechanic and the person holding the wheel what they should do (remove the wheel, plan the installation, and then reinstall it with the new screw).
Thank you for your help,
MWeid
No new posts Doku Golf 1J, Telefonlautstärke verstellt sich von selbst Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1Z Spritzbeginn verstellt!? Diesel Engine Technology
No new posts Is the mechanism for adjusting the valve stroke out of ad... Diesel Engine Technology
No new posts Einspritzbeginn verstellt -> KW Schraube 1Z? Diesel Engine Technology
No new posts Einspritzzeitpunkt anzeigen Diesel Engine Technology
