Exhaust Manifold Leak: Common Causes & Fixes
Mr.Richi
Post21-09-2007, 13:59    Subject: Exhaust Manifold Leak: Common Causes & Fixes Quote
I had my Golf 2 TD (with SB engine) at the workshop, and now it's blowing exhaust out of a hole on the original exhaust manifold.
Specifically, this hole is located on the right-hand side when facing forward, underneath or next to the turbocharger.
Right next to it is another threaded bolt, and about 4 cm further along is the hole (approximately an 8mm or 10mm hole).
I'm now wondering if something important is missing, or what could possibly be missing.
Unfortunately, I have to stay at work and probably won't be able to get to the workshop until Monday, which is why I'm asking this question.
I think you'll immediately know what this is, right?
I found a picture and I've marked the hole I'm referring to in red.
http://web16.torvalds.ebiz-webhosting.de/Bilder/Abgaskruemmer.jpg
Translated on 29-07-2026, 12:20.
Karma: +643 / -0   Thank you, like it!
Post21-09-2007, 20:28    Subject: Exhaust Manifold Leak: Common Causes & Fixes Quote
"Normally, there's a threaded bolt in there, and the protective plate is screwed onto it."
Translated on 29-07-2026, 12:21.
Mr.Richi
Post22-09-2007, 4:40    Subject: Exhaust Manifold Leak: Common Causes & Fixes Quote
Okay, so I did it right when I screwed in that screw.
No new posts OT Setting per Week OT Sensor Borehole Diesel Engine Technology
No new posts AFN mit 81mm Bohrung - ZKD? Pleuel? Diesel Engine Technology
No new posts Oil Leak at AXR Bore Hole near AGR Valve Diesel Engine Technology
No new posts The ventilation is blowing hot air into the interior Transmission, Chassis, Body & Interior
