Clutch Noise: Causes and Solutions
dokky
2013 Volkswagen Golf
Post07-06-2008, 13:31    Subject: Clutch Noise: Causes and Solutions Quote
Hi everyone,
I have a question. I drive a new Fiat Bravo 1.9 Multijet 16V. When pressing the clutch pedal while stationary, the engine noise gets louder. It sounds subjectively like knocking, which disappears when the clutch is fully engaged. When engaging the clutch while driving, you can hear a slight "rumbling" as the engine speed drops. The pedal feels light, and the clutch engagement is very smooth.
According to the workshop, it's a "normal" operating noise. Since I've only driven 11,500 km and the car is still under warranty, I'm not allowed to inspect it myself. I haven't been able to test another vehicle with the same engine yet.
Is that something to be ignored?
Translated on 13-08-2026, 21:20.
BM
Avatar-BM
Post07-06-2008, 20:41    Subject: Clutch Noise: Causes and Solutions Quote
I drive a new Fiat Bravo 1.9 Multijet 16V. When pressing the clutch pedal while stationary, the engine noise gets louder. Subjectively, it sounds like knocking, which disappears when the clutch is fully engaged. While engaging the clutch during driving, you can hear a slight "rumbling" as the engine speed drops. The pedal is easy to press, and the clutch engagement is very smooth.
If this Fiat still has a clutch cable, it is possible that the noise could be transmitted from the cable to the pedal assembly if the cable is under tension. In that case, it would be considered normal.
3B5 AJM
Translated on 13-08-2026, 21:22.
dokky
Post08-06-2008, 1:01    Subject: Clutch Noise: Causes and Solutions Quote
Hydraulic actuation.
No new posts A4 1.9 TDI: Engine Jerks Like Clutch Slipping Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 8L Doku: Engine Noise Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Expansion Valve Sounds - A3 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts PD AUY Noises: Troubleshooting & Solutions Diesel Engine Technology
No new posts TDI 130 PS (AVF): Noises When Releasing Gas Diesel Engine Technology
No new posts Climatronic Noise: Audi A4 B4 Interior Sensor Issue Transmission, Chassis, Body & Interior
No new posts Engine Noise When Shutting Off Diesel Engine Technology
