Brake Performance and Engine Power
F B
Post25-04-2007, 7:15    Subject: Brake Performance and Engine Power Quote
Hi.
I have a question regarding the above topic.
There are some really nice cars out there, like the Mercedes-Benz ML AMG with 500 horsepower, etc.
Are the brakes only designed to bring the vehicle to a safe stop?
Or is it absolutely necessary to be able to stop every car, even with its engine running at full power?
I'm now thinking that for some reason, the electronics might be malfunctioning, causing the motor to be driven at full throttle, and I'm wondering if the braking performance is, by law, sufficient to bring the car to a stop.
When I think of Mercedes AMG cars now, I'm talking about models with up to 500 horsepower on the rear axle, which only has 20 to 30% of the braking power compared to the front axle.
Yes, the ML has all-wheel drive, but what about the other models?
Best regards, Frank.
Translated on 07-09-2026, 7:16.
wutz
Karma: +11 / -1   Thank you, like it!
2006 Seat Leon
Post25-04-2007, 15:56    Subject: Brake Performance and Engine Power Quote
There's the clutch, and in automatic transmissions, the "N" (neutral) position. If the engine receives a full-load signal for any reason, the safest method is to decouple the power from the drivetrain.
Translated on 07-09-2026, 7:17.
mahk
Avatar-mahk
Post25-04-2007, 16:52    Subject: Brake Performance and Engine Power Quote
if one is to believe: http://www.spiegel.de/auto/aktuell/0,1518,321452,00.html
It doesn't seem easy to brake while accelerating. The report doesn't explain why engaging the "N" (neutral) position didn't help.
Typ89 SB: 05/2000 120.000km - 01/2005 295.000km (unfall)
B5 Avant AEB 07/2005 166.000km ([email protected]) - 07/2007 195.000km (verkauft)
1K BMM: 03/2011 120.000 km - aktuell
Jochen_145
Post25-04-2007, 17:10    Subject: Brake Performance and Engine Power Quote
If you calculate the braking power of a vehicle, considering that it comes to a complete stop from 100 km/h within 40 meters, and express that power in horsepower, you will see how significant the power of the brakes is.
This is significantly larger than the driving force.
For a 911 Turbo, I'm aiming for power outputs in the range of over 1000 horsepower (0-100 km/h in approximately 2.2 seconds).
Therefore, I should be able to, and can (it works perfectly fine with my diesel car), use the brake pedal to slow the car down even when accelerating fully, to the extent that, in extreme cases, I can stall the engine.
Left-side brakes operate according to the exact same principle and significantly reduce the vehicle's speed.
A disadvantage of this method is:
The brakes are subjected to very high thermal stress.
However, I once heard someone say, in a friendly way, that you can't press the brake and accelerate at the same time. I managed to convince them otherwise.
Best regards, Jochen.
Translated on 07-09-2026, 7:19.
Post25-04-2007, 17:15    Subject: Brake Performance and Engine Power Quote
Well, personally, I don't believe much of it, except that the colleague from France was apparently very busy.
There are, even in a Renault, countless ways to manipulate the engine's power output. And the fact that *all* braking mechanisms failed, but *all* components responsible for acceleration worked perfectly... that's very strange.
The E63 AMG has an automatic transmission, which will automatically disengage once you've installed the brake pads onto the drilled brake rotors all around.
PS: My GRA will activate on its own when the ESP says "go" - done this icon_twisted.gif.
Translated on 07-09-2026, 7:21.
bloesch
Post25-04-2007, 17:37    Subject: Brake Performance and Engine Power Quote
So, my father's 1996(?) Lexus wouldn't "cooperate" when it came to stopping, after the accelerator pedal got stuck under the floor mat in the "kick-down" position.
The software probably interpreted this as an incline and simply downshifted, allowing it to continue smoothly.
My dad didn't turn on the TV; icon_cool.gif instead, he was messing around in the footwell at a speed of 160.
Translated on 07-09-2026, 7:22.
Avatar-Jan6K
Post25-04-2007, 17:52    Subject: Brake Performance and Engine Power Quote
However, I once heard someone say, in a friendly way, that you can't press the accelerator pedal at the same time as you press the brake. I managed to convince them otherwise.
I think that's possible, but: The TDI might detect this through the brake switches... I'm not sure if it will actually provide full power when the pedal is pressed, or if it will only provide a little less.
Regarding the Frenchman: I think we've already discussed this. Either it was just a lame excuse, or he braked too gently, causing the brake pads to glaze over. With a brutal full stop, the car should have come to a complete stop.
Jan.
1Z5 CFHF / AHB H4D
Translated on 07-09-2026, 7:24.
leo_b
Avatar-leo_b
Post25-04-2007, 18:09    Subject: Brakes and Gas: How to Control Your Car Quote
hi,
Two brake switches are installed in the T4 TDI models.
One is for the brake light, the other is for the message.
If you press the accelerator and brake pedal at the same time, the engine will only run at a higher idle speed (approximately 1200 RPM).
If you suddenly press the accelerator from zero to full, the engine will respond based on the accelerator pedal position.
Best regards, Leo.
edith: because of a typo. icon_wink.gif
Mein Bussi: Trapo, 7/1999, Kombi L, 8 Sitze, Indianblau, 88PS (65kW) TDI, MKB: AJT, GKB: DUJ, mit kleinem LLK, 340000km
Translated on 07-09-2026, 7:25.
Jochen_145
Post25-04-2007, 18:58    Subject: Brake Performance and Engine Power Quote
I believe that's possible, but: The TDI might detect this through the brake switches... I don't know if it will actually give full power when the pedal is pressed down, or if it will only give a little less.
Hello Jan,
For the 'older' TDIs (AHU, ASV), it's full throttle.
'It always downshifts with intermediate gas. Depending on how much I press the accelerator, the RPMs increase. Going above 3500 RPM isn't a problem; I rarely rev higher when downshifting.'
The rental BKC (105 hp, Golf V) that I drove could also be downshifted with intermediate throttle.
I don't currently know about the other PDs.
I've attached a quick-and-dirty intermediate gas pressure reading I found. (t = approximately 2255 seconds.)
The braking was not excessively hard.
Considering the level of Engine_Load (the PWM signal of the VP control), it is similar during a brief throttle lift-off as it is during subsequent acceleration.
It shows: after all, it's about icon_smile.gif
 File size:  81.94 KB
 Viewed:  3183 times
Translated on 07-09-2026, 7:27.
F B
Post25-04-2007, 19:04    Subject: Brake Performance and Engine Power Quote
There is the clutch, and in automatic transmissions, the 'N' position. If the engine receives a full load signal for any reason, the safest method is to decouple the power from the drivetrain.
Hey there!
Unfortunately, that wasn't the question.
Turning off the ignition might also help, but I didn't ask about that.
I can vividly imagine forcing a front-wheel-drive car to oversteer by applying the brakes while accelerating.
It seems a bit insufficient to have a Benz with 500 horsepower on the rear axle and a rear brake that only needs to provide 25% of the total braking force.
It might look funny if the front wheels are stationary, but then the rear wheels would first be the brakes, and then the rims could overheat.
I actually wanted to know if the braking power needs to be higher than the engine power, and whether the drive axle/brakes alone have to be able to handle it.
I would like to know which law, regulation, DIN standard, etc. governs such a matter.
Translated on 07-09-2026, 7:30.
bloesch
Post25-04-2007, 19:26    Subject: Brake Performance and Engine Power Quote
I can't think of a specific legal basis for that off the top of my head.
But maybe you should take a look at the German Road Traffic Regulations (STVZO) sometime.
Sure, please provide the text you would like me to translate from German to English.
Road Traffic Licensing Regulations (StVZO).
B. Vehicles.
III. Construction and operational regulations.
§41 Brakes and wheel chocks.
...(4) For motor vehicles - excluding motorcycles - a mean full deceleration of at least 5.0 m/s² must be achieved using the service brake; however, for motor vehicles with a maximum speed, as determined by their design, of no more than 25 km/h, a mean full deceleration of 3.5 m/s² is sufficient.
or
§65 Brakes
(2) Any device that is securely attached to the vehicle and is capable of reducing the vehicle's speed and bringing the vehicle to a stop shall be considered an adequate brake.
"By the way, rear-wheel drive vehicles (at least as far as I know from all-wheel drive systems) likely have significantly more than 25% of the weight on the rear axle... probably closer to 40%."
It might look funny if the front wheels are stationary; then the rear wheels would first be the brakes, and then the rims would start to glow.
which brings us back to the old Lexus.
- Black ice: Engage driving mode D and apply the brakes.
--> The front wheels lock up, while the rear wheels propel the car forward at approximately 3 km/h.
Translated on 07-09-2026, 7:33.
Avatar-Jan6K
Post25-04-2007, 23:10    Subject: Brake Performance and Engine Power Quote
"It always downshifts with intermediate gas. Depending on how much I press the accelerator, the RPMs increase. Going above 3500 RPM isn't a problem; I rarely rev higher when downshifting."
Okay... maybe we're not understanding each other... I definitely mean the scenario where the clutch is engaged, a gear is selected, the brake is applied, and the accelerator is fully pressed. You're not doing that when you're downshifting with throttle blipping – either you're pressing the clutch or you're not in a gear, meaning there's no power transfer between the engine and the wheels.
Or have I misunderstood something else that you meant?
It seems a bit insufficient to have a rear brake that only needs to provide 25% of the total braking force, especially considering a Mercedes with 500 horsepower at the rear axle.
Hmm... yes... that is quite interesting.
The 25% figure essentially results from the fact that the rear wheels, which are unloaded during braking, can only transmit 25% of the braking force before they lock up. This doesn't mean that the brakes aren't powerful; I'm not sure what size brake rotors are on the rear, but for 500 horsepower, they probably don't need to be excessively large.
Looking at my 280 (or were they 288?) 22mm internally ventilated front discs, which almost single-handedly provide the braking power for the Ibiza and can operate right at the limit of adhesion during a 100->0 km/h braking maneuver, that's probably roughly equivalent to what's needed for a 0->100 km/h acceleration in 4...5 seconds – which also translates to well over 300 horsepower of braking power. However, the rear discs on that Mercedes are probably more robust than mine... so I can definitely imagine that.
Jan.
1Z5 CFHF / AHB H4D
Translated on 07-09-2026, 7:37.
Jochen_145
Post26-04-2007, 11:14    Subject: Brake Performance and Engine Power Quote
Moment... maybe we're talking about different things... I definitely mean the scenario where the clutch is engaged, a gear is selected, the brake is applied, and the accelerator is fully pressed. You don't do that when downshifting with throttle blipping - either you've pressed the clutch or you're not in a gear, so there's no power transfer between the engine and the wheels.
Oh, yes, we will probably do that icon_redface.gif.
When you apply the brakes while in gear and simultaneously give full throttle, the load request, and therefore the fuel injection amount, is initially limited by the driver's request and the engine speed. (Fuel quantity requested = function(driver request / engine speed)).
Depending on the speed and characteristic curve, I can already request the maximum amount here.
Since the speed is unlikely to change much (or at all, as the engaged brake prevents an increase in speed), you are correct that while you can request the maximum amount, it will not correspond to the maximum possible full load amount. It will be limited by the smoke curve and the torque limiter.
If you now apply stronger braking and reduce the engine speed, the amount of fuel delivered is increasingly reduced according to torque and smoke limits. Consequently, even with 100% pedal input, the engine does not release the maximum possible amount of fuel, and it can be braked all the way to stalling using only the brake.
Actually, I don't need a brake switch to limit the amount in this case. The limits on the injection amount are sufficient for this purpose.
'Well, it's a bit complicated to describe, but I hope it was somewhat understandable.'
Actually, in this case, you are operating within fixed load points that are controlled by the engine control unit (ECU) via the injection quantities.
I hope I now understand what you meant.
Translated on 07-09-2026, 7:41.
Avatar-Jan6K
Post26-04-2007, 15:25    Subject: Brake Performance and Engine Power Quote
Okay, so we're on the same page now.
"That's quite a bit of material wear and tear... I would have implemented it so that when the brake pedal is pressed and the engine speed is above idle, the fuel injection is completely shut off, regardless of what the driver does with the accelerator pedal. I haven't tested it... but if you say that the anti-stall valve actually still injects fuel in that case, then mine probably does too."
Jan.
1Z5 CFHF / AHB H4D
Translated on 07-09-2026, 7:44.
Jochen_145
Post26-04-2007, 15:50    Subject: Brake Performance and Engine Power Quote
I haven't tested it... but if you say that the ASV actually injects more in that case, then mine probably will too.
Hello Jan,
You can easily try this out:
Try to gently brake with your left foot while simultaneously accelerating (but be very careful, it's not a clutch icon_wink.gif), I initially gripped the steering wheel quite tightly icon_sad.gif).
Then, brake with the same intensity without pressing the accelerator.
The difference is noticeable, even if you only give it a little bit of gas.
It's quite a material waste, though... I would have implemented it so that when the brake pedal is pressed and the engine speed is above idle, the fuel injection is completely shut off, regardless of what the driver does with the accelerator pedal.
You're right, in principle, it can be done that way.
Perhaps people thought that only crazy people would brake and accelerate at the same time.
An average rider would likely feel a jolt in their legs there, and if you brake with the right side, you're probably already in the traction control or wheelie limit mode.
You can do without that switch.
Translated on 07-09-2026, 7:46.
Avatar-Jan6K
Post26-04-2007, 22:01    Subject: Brake Performance and Engine Power Quote
Basically, yes... but it's already there and being monitored, partly to disable the GRA (presumably a system or function). So, it would essentially be a software issue.
But you're probably right... It's probably due to developer laziness.
I'll take the test tomorrow.
By the way, I always do something similar when I'm starting the car on a hill or in a parking garage. I generally do it without using the handbrake, just the foot brake. Clutch and neutral. It works perfectly, especially with the strict LL (low-speed) regulations of the ASV (presumably a specific system or organization).
Jan.
1Z5 CFHF / AHB H4D
Translated on 07-09-2026, 7:49.
No new posts TDI V6: Documenting Engine Power Loss Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Engine Problems: Low Power & Error Code 00553 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Performance: A4, B5 & More in Heavy Rain Transmission, Chassis, Body & Interior
No new posts Engine Power & RPM: Explained Simply Diesel Engine Technology
No new posts Question about engine power Diesel Engine Technology
No new posts Low Engine Performance Causes Diesel Engine Technology
