Audi A4 Rear Axle Brake Failure Repair
Go to page: 1, 2  Next
cksIT
Post20-04-2007, 11:14    Subject: Audi A4 Rear Axle Brake Failure Repair Quote
I have almost no braking power on the rear axle of my Audi A4.
The brake discs look like this:
Right side: Outer surface with scattered rust spots (depressions) distributed across the entire disc.
The inner surface is completely worn out except for a 0.5 cm wide ring that protrudes (there is a corresponding indentation in the brake pad).
Left side: Outside is unused, inside is used; outside is used.
Inside used, outside unused.
each at 50% (the correct edge is in the center of the disc).
Since the TÜV inspection is coming up, I probably need to do something icon_smile.gif.
On the right side, I quickly realized why the outside looked so strange: one of the guide pins in the brake caliper was heavily rusted. I then loosened it, cleaned it, and re-greased it (it now moves completely smoothly).
Furthermore, the handbrake lever was stiff and difficult to move. After some back-and-forth movement, it started working properly again. However, it will still be replaced.
On the left side, however, everything was fine. The saddle also looked like it had been replaced before. All the parts were movable and in quite good condition... But where did this strange wear come from?
I will add some pictures later to illustrate this.
After replacing the rotors and pads (including wheel bearings), I'm seeing the beginnings of grooves appearing on the outer edges after just a few braking cycles. However, the grooves are distributed across the entire surface of the rotor, not just in one area.
Where does it come from?
Translated on 26-07-2026, 13:46.
Herr Antje
Post20-04-2007, 11:30    Subject: Audi A4 Rear Axle Brake Failure Repair Quote
I suspect either worn or stuck linings (which is common), or too much play in the guide bolts, which could cause the saddle to tilt somehow (that's what the wear pattern suggests).
Make sure the brake pad alignment on the seat stay is perfectly flat and use brake grease.
To be on the safe side, you should get a new rack and a new saddle.
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 26-07-2026, 13:49.
cksIT
Post20-04-2007, 12:00    Subject: Audi A4 Rear Axle Brake Failure Repair Quote
The brake pads are not seating properly, and the guide pins also have no play. The contact surface is fine... I'm not entirely sure what's going on. I need to get this fixed for the TÜV (German technical inspection). Normally, I wouldn't worry about the handbrake as long as there isn't a significant difference between the left and right sides.
I always use copper grease paste, mainly to prevent squeaking. I guess I'll have to go looking for a brake caliper now.
Translated on 26-07-2026, 13:50.
BM
Avatar-BM
Post20-04-2007, 13:25    Subject: Audi A4 Rear Axle Brake Failure Repair Quote
Furthermore, the handbrake lever was stiff, but after some back-and-forth movement, it worked fine again. --> It will still be replaced.
The pads were not tight, and the guide pins also have no play. The contact surface is fine... I'm not entirely sure what's going on there...
You already wrote the answer yourself. If everything is working now, I'll just observe the grooves for now.
3B5 AJM
Translated on 26-07-2026, 13:52.
Herr Antje
Post20-04-2007, 21:00    Subject: Audi A4 Rear Axle Brake Failure Repair Quote
Unfortunately, the fix with the handbrake lever often only lasts for a short time and doesn't explain the wear pattern.
If the brake pads are now fully engaged, I would initially just observe the formation of grooves. If you have even pressure, the grooves likely only come from the structure of the disc or the pad material...
Aktuell:
Translated on 26-07-2026, 13:53.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post21-04-2007, 8:42    Subject: Audi A4 Rear Axle Brake Failure Repair Quote
[quote="cksIT".... brauchs halt für den tüv jetzt... normalerweise wäre mir die Handbremse egal... solange nur keine zu große differenz zwischen links und rechts herrscht.
benutze übrigends immer kupferpaste, alleine schon wegen dem quitschen. werde dann wohl mal Bremssattel suchen gehen.../quote]
I would apply the brakes fully and evenly now, initially braking gently (frequently engaging the handbrake while it's still cool), and then checking for control.
Am I understanding correctly that it has 165 horsepower, and you only need the rear brakes for the TÜV (technical inspection)? icon_lol.gif
Regarding copper paste: Ceramic paste is all the rage right now!
Regarding saddle replacement: it's always best to replace them in pairs, and then everything will be fine!
[/quote]
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 26-07-2026, 13:54.
cksIT
Post21-04-2007, 9:37    Subject: Audi A4 Rear Axle Brake Failure Repair Quote
Well, as long as they don't brake too differently and still actually brake, it's okay. After all, the rear brake doesn't really contribute that much anyway... (20%).
What is the advantage of ceramic paste compared to copper paste?
I'll see if I can get a few saddles icon_smile.gif. Then I can have them painted at the same time, so I don't have to be without my car during that period }.
Translated on 26-07-2026, 13:55.
bastion
Karma: +6 / -1   Thank you, like it!
Post21-04-2007, 11:53    Subject: Audi A4 Rear Axle Brake Failure Repair Quote
cksIT wrote:
[...Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
The advantage is that the aluminum parts on the calipers don't corrode. In some new vehicle models, the brake calipers are made entirely of aluminum.
A4 Avant 08/01 AWX 05/08-
Translated on 26-07-2026, 13:56.
Herr Antje
Post21-04-2007, 17:46    Subject: Audi A4 Rear Axle Brake Failure Repair Quote
Copper paste could also cause problems with the ABS sensors (which are magnetic), as far as I know, that's the only reason.
Aktuell:
Translated on 26-07-2026, 13:57.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post21-04-2007, 18:30    Subject: Ceramic Paste: Copper Paste for Sale Quote
Herr Antje wrote:
Copper paste could also cause problems with the ABS sensors (magnetic), as far as I know, that's the only reason.
Copper is not magnetic.
The text refers to the electrochemical series, and it seems that aluminum and copper are not behaving as expected ("not quite green").
As galvanic elements, copper has a potential of +0.52 volts and aluminum has a potential of -1.66 volts.
This results in a combined voltage of 2.18 volts in the worst-case scenario.
Translated on 26-07-2026, 13:58.
BM
Avatar-BM
Post21-04-2007, 19:02    Subject: Audi A4 Rear Axle Brake Failure Repair Quote
Aluminum and copper are not really "green" in terms of environmental impact!
That's correct. However, so far, I haven't found anything more effective than copper paste for the area between the brake caliper and the brake pads, as it prevents corrosion until the end of the pads' lifespan.
Well, as long as they don't brake too differently and still actually brake, that's okay, because the rear brake doesn't really contribute much anyway... (20%)
@cksITViewing profile: cksIT
In practice, and in the age of ABS, this is actually more than 20%, not to mention the potential for over-reliance on the front brakes when applying the same amount of braking force.
If you don't know what you're writing about, it's best to leave it alone.
3B5 AJM
Translated on 26-07-2026, 14:00.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post21-04-2007, 19:20    Subject: Audi A4 Rear Axle Brake Failure Repair Quote
BM wrote:
That's correct. However, so far, I haven't found anything more effective than copper paste for the area between the brake caliper and the brake pads, as it prevents corrosion until the pads wear out completely.
It's likely because an aluminum saddle wasn't used; with cast iron or gray cast iron, it won't play as significant a role.
There used to be anti-squeal compound included in the packaging with the brake pads.
I also have it in the cupboard as a spray. It is also suitable for exhaust connections.
So, copper also works... 'icon_wink.gif' ...still.
PS: He urgently needs the rear brake performance! In my opinion, during full braking, there is initially no dynamic load transfer to the rear axle that would be disadvantageous. At best, all four wheels lock up briefly (or mostly the rear ones), and then the rear lifts.
As you brake more and more gently, the rear end starts to lift up more noticeably, and if it has an ALB (Anti-lock Brake System), pressure will be automatically reduced.
Is it correct that since the introduction of ABS, ALB is no longer used? icon_redface.gif
However, he's partially correct; the braking force of the front brakes is usually twice as strong as that of the rear brakes (due to a larger friction surface plus about 30%, and the point of application being further out). This means that the rear brakes don't have much work to do.
Translated on 26-07-2026, 14:02.
BM
Avatar-BM
Post22-04-2007, 0:01    Subject: Audi A4 Rear Axle Brake Failure Repair Quote
But he is partially right; the braking force of the front VA brakes is usually twice as large as that of the rear brakes (due to the friction surface being larger plus about 30% more, and the point of application being further out) so there is little demand on the rear brakes.
Several factors are involved there, which cannot be explained in a few sentences.
Approximately 30% braking force on the rear axle is already possible, and in some cases even more, depending on the load. You cannot ignore the effect of the rear brakes; for example, if you need to brake harder in curves, the ABS will reduce the braking force because you are losing too much traction or grip, or you may experience severe understeer (like R. Schumacher). icon_lol.gif Regardless, the car will not brake properly. On older 190 models (W201), if driven aggressively, the front brake discs will overheat within 200 km if the rear brakes are only providing half or less of the potential 30% braking force.
3B5 AJM
Translated on 26-07-2026, 14:05.
cksIT
Post22-04-2007, 20:37    Subject: Audi A4 Rear Axle Brake Failure Repair Quote
It doesn't really matter anyway, as I want to bring the speed back down, or rather, I would say it's slowing down again now... At least, the wear and tear looks quite even so far.
"The ridges are present everywhere there are holes in the brake disc; I suspect that's where they originate from..."
Now I'm just left with the problem that the right brake caliper has a hole in the boot of the piston.
Has anyone ever rebuilt a brake caliper before? What should you be aware of when doing it? I don't want to just start taking things apart without knowing anything, maybe there are some specific tricks or techniques that one should know.
I just don't really want to spend €200 if I can simply refurbish the saddle instead.
Translated on 26-07-2026, 14:07.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post22-04-2007, 21:34    Subject: Audi A4 Rear Axle Brake Failure Repair Quote
Hello.
Do you now have new perforated brake surfaces (like those from Zimmermann), and that's why you're experiencing vibrations/grooves?
If you have a torn dust boot, it can be replaced. However, if the boot is brittle, the brake may have overheated, causing the material to become fragile.
Disassembly and overhaul are not possible; instead, we offer replacements at a reasonable price with a warranty. For example, Budweg or Caliper products.
Translated on 26-07-2026, 14:09.
BM
Avatar-BM
Post22-04-2007, 22:15    Subject: Audi A4 Rear Axle Brake Failure Repair Quote
Zerlegen und überholen ist nicht- gib es im Tausch günstig und mit Garantie ZB. Bsolution / caliper
The seal and gasket are available for icon_biggrin.gif at a price of 19 EUR. I don't see why you would need to replace the entire saddle if it is otherwise okay, just because the gasket is defective.
The repair process is straightforward once the piston has been pushed out using the handbrake lever.
3B5 AJM
Translated on 26-07-2026, 14:10.
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts C4 AEL Coolant Temp Display Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Parking Assist Fault: Audi A6 (4B) Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi B4 Quattro Won't Start: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts MFA malfunction On-Board Diagnostics (OBD)
No new posts LMM Failure: Troubleshooting & Repair Guide On-Board Diagnostics (OBD)
No new posts LMM failure? On-Board Diagnostics (OBD)
