Climatronic Error Codes: Troubleshooting Guide
Zimbo30
Post16-08-2006, 14:05    Subject: Climatronic Error Codes: Troubleshooting Guide Quote
I used VAG-COM to read the error codes from my Passat, manufactured in 2002, and the following errors were found:
00603 - Actuator motor for footwell/defrost flap (V85)
35-10 - - - Interrupted.
01271 - Temperature flap control motor (V68)
01272 - Actuator motor for central locking (V70).
01274 - Actuator for pressure relief valve (V71).
I've noticed that when the car's air conditioning is running, the blower motor briefly speeds up and then slows down again, sometimes repeatedly. I'm not sure if this is normal or if it's related to a problem.
I've already cleared the error codes and reset the climate control to its default settings, but the errors keep reappearing.
Best regards, Dirk.
Translated on 03-10-2026, 22:47.
scrdel
Karma: +4 / -2   Thank you, like it!
2002 Volkswagen Passat
Post15-04-2007, 18:31    Subject: Climatronic Error Codes: Troubleshooting Guide Quote
Hello, I've dug up this old thread about the search function because it's very similar to the problem I'm experiencing.
Regarding the Passat:
The following behavior of the Climatronic system has been observed:
While driving, the amount of air coming out of the vents varies.
It can range from completely off to full power, but the fan motor always runs at the set speed.
The throttle valve (V71) is constantly opening and closing, as viewed from the engine compartment. The pollen filter has been removed and inspected, and in some cases, the valve remains open, and the shaft vibrates (the shaft tries to move).
The error memory indicates the following:
Control unit part number: 3B1 907 044 H
Component and/or version: CLIMATRONIC B5GP 0009
Encoding: 17000
"One error found:"
35-00 - -
and
Encoding: 17000
"One error found:"
35-10 - - - Sporadically
I've already tried performing a basic calibration and actuator diagnosis, but the error keeps recurring.
Does the motor now need to be replaced, or does the potentiometer (or is that a component?) need to be replaced? Are there any other ways to achieve the desired result?
Thank you, Sven.
Passat Variant Highline 2,0 TDI 103KW
Translated on 03-10-2026, 22:51.
Zimbo30
Post15-04-2007, 19:59    Subject: Climatronic Error Codes: Troubleshooting Guide Quote
Hello Sven,
My post is a bit old, but it's still relevant.
I'm still having problems with it.
It seems like the fan is...
Run fast for a bit, then slow down again.
Könnte aber wie du sagst auch die Klappe sein. Wanted.
Let's take a look at that later.
Translated on 03-10-2026, 22:53.
pax
Avatar-pax
2000 Volkswagen Passat
Post15-04-2007, 20:10    Subject: Climatronic Error Codes: Troubleshooting Guide Translating...
[Translating...]
zu diesen Fehlern gibts im Passatforum einen grossen Thread. Offenbar gibt es für diese Probleme keine eindeutige Lösung. Manchmal hilft Bedienteil tauschen, manchmal Motoren tauschen und manchmal sollen wohl die Motoren bzw. die betätigten Klappen am Gebläsekasten hängen und Fehlereinträge hervorrufen.
Bye
pax
scrdel
Post18-04-2007, 18:03    Subject: Climatronic Error Codes: Troubleshooting Guide Translating...
[Translating...]
Hallo, das schwanken des Luftdurchsatzes an den Ausströmern kommt bei mir definitiv von der nicht korrekt arbeitenden Staudruckklappe.
Die Klappe für Umluftbetrieb wird vom selben Motor gesteuert, funktioniert aber ???
Ob die Staudruckklappe funzt oder nicht kann man einfach testen (glaube ich )
1.
Lüftung an, (Econ oder Auto ist egal) auf Umluft schalten, dann Klimatronic ausschalten.
Ergebnis sollte sein das kein Lufthauch mehr aus den Düsen kommt.
2.
Lüftung wieder an, Umluft ausschalten, Lüftung wieder ausschalten, wenn jetzt trotz ausgeschalteter Klimatronic noch Luft aus den Düsen kommt ist die Staudruckklappe im POPO, weil sie nicht richtig schließt.
Die Staudruck und Umluftklappe liegen übereinander.
Könnte mal wer ausprobieren bei funktionierender Klimatronic ob es tatsächlich so ist das bei vorher Umluft aus und dann ausgeschalteter Klimatronic bei Ihm kein Lufthauch aus den Düsen kommt??
Ich gehe jetzt mein Handschuhfach ausbauen ....
Sven
scrdel
Post18-04-2007, 20:37    Subject: Climatronic Error Codes: Troubleshooting Guide Translating...
[Translating...]
... so, habe jetzt den V71 ausgebaut (überlege mich als Schlangenmensch bei Roncalli zu bewerben !).
Geht tatsächlich relativ einfach, ist aber ein wenig quälerei....
Habe im ausgebauten Zustand nochmal getestet, Klappen sind freigängig, der Motor läuft sobald er Spannung bekommt immer hin und her, teilweise zuckt er ein paar mm hin und her.
Ich denke der findest seine Endanschläge nicht mehr.
Habe mal ein paar Bilder gemacht:
www.sven-r.magix.net
Album Stellmotor Climatronic V71
Im Album unten rechts auf die beiden Pfeile klicken=Vollbild.
Wo außer bei VW bekomme ich den Motor ??
ET Nr: 8D1 820 511 E
Hersteller ist Bosch.
scrdel
Post21-04-2007, 13:53    Subject: Climatronic Error Codes: Troubleshooting Guide Translating...
[Translating...]
... so, habe den neuen Stellmotor jetzt drin.
Alte Fehlercodes gelöscht, mit VAG COM neue Grundeinstellung durchgeführt.
Stellglieddiagnose ausgeführt, nochmal Fehlerspeicher ausgelesen, siehe da keine Fehler mehr drin. (sonst immer gleich wieder da gewesen)
Anlage funktioniert auch wieder tadellos.
Nach ein paar Tagen mal wieder über die Eigendiagnose der Climatronic den Fehlerspeicher ausgelesen, steht wieder was drinn, mehrmals gelöscht, steht immer wieder was drinn, aber immer andere Sachen.
Ich nehme das jetzt so hin, das der Krempel nichts taugt, funktionieren tuts ja und gut.
Sven
No new posts Error Codes, Causes and Effects for MKB ASZ, AXR, ATD Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error codes 19804/P3348 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB AMF Error Codes: Causes and Effects Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV Error Codes: Troubleshooting & Solutions Diesel Engine Technology
No new posts VAG-COM error codes On-Board Diagnostics (OBD)
No new posts Error Codes: Troubleshooting & Solutions On-Board Diagnostics (OBD)
No new posts VW T4 Error Codes: Troubleshooting Guide On-Board Diagnostics (OBD)
