A4 Dashboard (Instrument Cluster) Replacement?
datsun
Post29-04-2008, 19:43    Subject: A4 Dashboard (Instrument Cluster) Replacement? Quote
Hello everyone,
I need your advice. My instrument cluster is malfunctioning; all the needles and lights flicker below 10 degrees Celsius. This seems to be a common problem with instrument clusters without Fis from Jaeger (manufactured in 2000). I've read something about a 'chip bonding' issue.
What happens if you plug a used AI into a FIS and leave one connector unused? Okay, the immobilizer will need to be programmed.
Does anyone have any experience?
Thank you very much.
Rainer.
Translated on 28-08-2026, 21:10.
datsun
Post06-05-2008, 20:16    Subject: A4 Dashboard (Instrument Cluster) Replacement? Quote
Does anyone have any idea if the standard functions work when using a FIS speedometer?
Thank you.
Rainer.
Translated on 28-08-2026, 21:11.
Audifahrer
Post07-05-2008, 9:31    Subject: A4 Dashboard (Instrument Cluster) Replacement? Quote
"So, if you're already integrating an AI system with a FIS (Fish Identification System), I would also recommend adding a switch for it."
The switch costs around 40 euros.
If that's too much, you can simply connect the unnecessary signals to ground.
You also need to extract the login code.
That's actually quite simple with an A4, using a cheap EEPROM programmer from Conrad.
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts VW Golf 4: Replace Analog Speedometer with FIS Display Transmission, Chassis, Body & Interior
No new posts 1.9 PD ASC Replacement Diesel Engine Technology
No new posts Exchange Pressure Can Diesel Engine Technology
No new posts Turbocharger Replacement: Buy Now! Diesel Engine Technology
