Fabia: No diagnosis possible when factory radio is connected!
reiner1980p
Post05-05-2007, 19:31    Subject: Fabia: No diagnosis possible when factory radio is connected! Quote
I'm having a problem. I bought a Symphony radio for my Fabia (factory radio), but now I can't access the diagnostic menu when the radio is connected. However, if I temporarily disconnect the diagnostic pin (3), I can access it immediately. I don't have this problem with any other control units! What could be the issue? Vehicle: Skoda Fabia Classic, manufactured in 2002. The diagnosis was performed using VAG diagnostic tool. When the engine is running, everything works, and I can access the instrument cluster.
Post06-05-2007, 11:15    Subject: Fabia: No diagnosis possible when factory radio is connected! Quote
Radio shorts diagnostic line -> defect. It happens often.
reiner1980p
Post06-05-2007, 12:02    Subject: Fabia: No diagnosis possible when factory radio is connected! Quote
Do you mean the radio is broken???
mullemaus
Post06-05-2007, 12:18    Subject: Fabia: No diagnosis possible when factory radio is connected! Quote
No, not necessarily; it might just be that the pin assignments are incorrect. So, let's check. icon_wink.gif
reiner1980p
Post06-05-2007, 12:30    Subject: Fabia: No diagnosis possible when factory radio is connected! Quote
The pin configuration is correct. I just swapped the ignition and constant power connections because the radio kept forgetting the code.
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Polo 9N / Ibiza 6L / Fabia 2: Generator does not charge Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BLS - Erratic idle when AC is on - and more Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI No Power When Warm: Log File Analysis On-Board Diagnostics (OBD)
No new posts A6 4A: No Diagnosis Possible On-Board Diagnostics (OBD)
No new posts Problems, no diagnosis with a Lupo 1.7 SDI AKU, built in ... On-Board Diagnostics (OBD)
No new posts Passat B7 TDI: VCDS Diagnostics, No Data Blocks On-Board Diagnostics (OBD)
