Golf 3 1Z ECU Replacement: Problems & Troubleshooting
vnt17
Karma: +0 / -2   Thank you, like it!
Post03-05-2007, 20:21    Subject: Golf 3 1Z ECU Replacement: Problems & Troubleshooting Quote
I replaced my ...C (part number) control unit with a ...D control unit from an Audi 80. The purpose of this was that the ...D unit had been modified by having its connectors soldered onto it for chip tuning. I received the control unit poorly packaged, loose in a cardboard box. Something inside was rattling, and upon opening it, it turned out that an EEPROM had fallen out of its socket and was bouncing around inside the control unit. I put it back in place and connected the control unit. The engine is running at an idle speed of 1200 RPM and doesn't respond to acceleration; or, after holding the accelerator pedal fully down for 5 seconds, it cuts out. -> Completely unusable.
So, what could be the cause? Is the control unit mechanically defective? Is the control unit not compatible with my engine? Are the tuning chips/maps junk?
Which chip controls what? If I open the control unit like a book and the connector is on the left, which chip controls the charger or pump – is it located at the top or bottom? Could I damage something if I were to swap the chips or use chips with incompatible specifications?
"Thank you."
alex
Translated on 06-08-2026, 15:57.
vnt17
Post04-05-2007, 17:41    Subject: Golf 3 1Z ECU Replacement: Problems & Troubleshooting Quote
It seems the 021D simply doesn't work well with the Golf.
especially since it's showing up as "021C" in VCDS (VAG-COM)?? How is that possible?
Control unit part number: 028 906 021 C.
Component or version: 1.9L R4 EDC SG D60.
Software coding: 00000
Workshop Code: WSC 00000
5 errors found:
00553 - Air mass sensor (G70)
28-10 - Short circuit after positive voltage - Interrupted.
00777 - Throttle position sensor (G79).
27-00 - implausible signal.
65535 - Control unit defective.
00-00 - -
00539 - Fuel temperature sensor (G81)
30-10 - Interruption / Short circuit after positive voltage - Interrupted.
00741 - Brake pedal monitoring.
27-10 - implausible signal - interrupted.
Data read from the measurement blocks:
coolant temperature -0.9°C
intake air temperature -7.2°C
Fuel temperature: 0.7°C.
The coolant temperature was 44 degrees Celsius at the other control unit.
and here from 021C:
No error code found.
Translated on 06-08-2026, 16:02.
Post04-05-2007, 18:35    Subject: Golf 3 1Z ECU Replacement: Problems & Troubleshooting Quote
especially since it shows up as 021C in the VCDS (VAG-COM) software?? how does that happen??
There was a "super tuner" involved, and they put in the wrong memory modules... icon_lol.gif
I've experienced that before too; the customer's car was running terribly. The chip tuning came from eBay.
Translated on 06-08-2026, 16:05.
vnt17
Post04-05-2007, 18:39    Subject: Golf 3 1Z ECU Replacement: Problems & Troubleshooting Quote
Assuming the correct EEPROMs or calibration data are used, would the engine control unit (ECU) function properly?
Translated on 06-08-2026, 16:06.
No new posts A6 4b 2,5TDI AKN BJ 99, woran erkennt man Facelift Transmission, Chassis, Body & Interior
No new posts erhöhter Verbrauch beim AFB - woran kann das liegen? Diesel Engine Technology
No new posts diesel filter on a Golf 3??? Diesel Engine Technology
No new posts habeauch das problem mit meine golf3 tdi 90 ps Diesel Engine Technology
