Why does a diesel engine become weaker over the years?
Hifi One
Post18-08-2003, 22:15    Subject: Why does a diesel engine become weaker over the years? Quote
Hello!
I suspect that the engine in my '96 Golf 3 TDI with the 1Z engine has become slightly weaker. Not much weaker, but a little bit. I feel like the engine ran smoothly around 120,000 km, and now at 210,000 km it's not quite the same. I might be wrong, but have you noticed anything similar?
I've already replaced everything new. Air filter, diesel filter, etc.
The decline in performance was gradual and not sudden. Therefore, no one who drives my car would notice it.
By the way, the turbo is 100% okay.
I also believe that the diesel pump needs lubrication, so I add 1 liter of 10W40 oil to my diesel tank every 20,000 km. However, I suspect that the pump may have some wear and tear, as it is a mechanical component. Even with good maintenance, this can happen. But I don't think there's a defect.
Maybe someone could tell me something about that!
Thank you in advance.
Andres Ortmann
Translated on 14-07-2026, 9:58.
diesel.gustav
Post19-08-2003, 0:34    Subject: Why does a diesel engine become weaker over the years? Quote
Deleted upon request.
Translated on 14-07-2026, 9:59.
No new posts VW Crafter: Second battery not charging Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts Information about glow plug spark plugs (glow plugs) Technical Articles
No new posts Why is it getting so hot? (Jetta JR) Pöl? Diesel Engine Technology
No new posts Warum wird die Einspritzpumpe vom Zahnriemen angetrieben? Diesel Engine Technology
No new posts World's most powerful diesel engine Diesel Engine Technology
No new posts Zahnriemenwechselbedingungen: km vs Jahre Diesel Engine Technology
