ATF Temperature: What You Need to Know
benutzer
Post13-06-2007, 13:23    Subject: ATF Temperature: What You Need to Know Quote
I received my semi-professional diagnostic system (VAG_COM 704-1) today.
"I'm planning to change the oil in my Tiptronic transmission soon, and since I need to know the oil temperature when filling, I would appreciate it if you could tell me how to read the temperature."
Yes, regarding question 2, is it possible to add a confirmation tone to the alarm system in my A6, manufactured in December 1998?
activate???
Thank you for your help!!!!!
Edit Mode:
Title changed, because "gear oil" is used in the manual transmission, while "ATF" (Automatic Transmission Fluid) is used in the torque converter of the automatic transmission.
Translated on 19-10-2026, 18:48.
Ross-Tech-Support
Post13-06-2007, 13:58    Subject: Gear Oil Temperature: What You Need to Know Quote
benutzer wrote:
Since I plan to change my oil in my TT soon, and I need to know the oil temperature when filling it, I would appreciate it if you could tell me how to read the temperature.
http://www.ross-tech.com/vag-com/cars/autotrans.html
For most automatic transmissions, the "Advanced Parameter Blocks" function should also be available, where you can directly select the desired value.
benutzer wrote:
Yes, question 2: Can I actually have a confirmation tone for the alarm system on my A6, manufactured in 12/98?
activate???
It should work...
http://de.openobd.org/audi/a6_4b.htm#35
Translated on 19-10-2026, 18:50.
benutzer
Post13-06-2007, 14:23    Subject: ATF Temperature: What You Need to Know Quote
Sure, thanks.
I need to try this right away, thank you very much!
Translated on 19-10-2026, 18:51.
benutzer
Post13-06-2007, 14:56    Subject: ATF Temperature: What You Need to Know Quote
The thing with the transmission oil worked perfectly icon_lol.gif.
In my coding for the central locking system, I have 04683 displayed. Now, if I want to activate the horn, what do I need to do?
+001024 - Close receipt (DWA horn).
Ross-Tech-Support
Post13-06-2007, 15:00    Subject: ATF Temperature: What You Need to Know Quote
The encoding is the sum of the individual options, so simply add 1024 to your current encoding, which will result in 05707.
Translated on 19-10-2026, 18:52.
benutzer
Post13-06-2007, 15:04    Subject: ATF Temperature: What You Need to Know Quote
"Really, thank you. I'll check that out, but I need to go play with my family now!!!"
benutzer
Post14-06-2007, 7:54    Subject: ATF Temperature: What You Need to Know Quote
It worked perfectly, thank you again for your help!!!!!
Translated on 19-10-2026, 18:53.
No new posts P0634 - Internal PCM/ECM/TCM temperature too high General Tips
No new posts TDI A4: Max. Particle Filter Temp. 170 PS Diesel Engine Technology
No new posts Cooler Fan On Temperature 1.6 TDI On-Board Diagnostics (OBD)
No new posts Climate Control: Set Temperature for Auxiliary Heater Transmission, Chassis, Body & Interior
No new posts Slipping Clutch in Cold Weather Diesel Engine Technology
