How to diagnose alternator play
bindpe
Karma: +5 / -2   Thank you, like it!
Post13-06-2007, 14:16    Subject: How to diagnose alternator play Quote
Hello forum.
I need a new alternator for my GIII TDI. Since I'm still a student, I'll probably have to go to a junkyard to find one.
How can you determine if the bearings in the alternator are still in good condition? Is it sufficient if the rotor cannot move back and forth?
Thank you for your responses.
Golf III TDI AHU 402Tkm
Spritmonitor.de
Translated on 05-10-2026, 9:25.
No new posts Installation of an aftermarket seat heater Troubleshooting & Guides
No new posts Disassembling the metering unit of a VP37 Troubleshooting & Guides
No new posts Function and components of an air conditioning system Technical Articles
No new posts Tripod joint, bearing clearance Transmission, Chassis, Body & Interior
No new posts Valve Guide Problems: How to Diagnose Diesel Engine Technology
No new posts Loader Problems: How to Diagnose G2 TD Issues Diesel Engine Technology
This topic is locked, you cannot edit or reply. Can You Determine Engine Mileage? On-Board Diagnostics (OBD)
