lambdapapst Blaumann
Joined: 09/22/2005 Posts: 14 Karma: +1 / -0 Location: Zossen bei Berlin
19-02-2008, 20:10 Subject: GOLF 3 Brake Drum ABS |
I need/have to replace the brake drums on my Golf 3. However, the new ones from the aftermarket supplier don't have an ABS sensor. Before I embarrass myself by potentially having the wrong parts or not knowing how to replace the ABS sensor, I'd rather ask about it publicly here.
Okay, let's be specific again. Are there different brake drums for vehicles with and without ABS? And if there is no difference, how is the sensor (not the sensor in the anchor plate!) modified?
Thank you for your help.
GOLF 3 GT SPECIAL TDI VARIANT, Bj.95, 1Z, ~390.000km
AGR Tot, Durchzug ~8,5sek, keine Bastelbude, kein Tuning
pax Profi-Schrauber
2000 Volkswagen Passat Support
19-02-2008, 22:31 Subject: GOLF 3 Brake Drum ABS |
The flywheel is about to come loose.
Bye.
peace
Profile PM Garage |
teileklaus Schrauber
Joined: 12/30/2006 Posts: 2643 Karma: +12 / -0 Location: Obrigheim 2005 Volkswagen Premium Support
19-02-2008, 22:43 Subject: GOLF 3 Brake Drum ABS |
That must be a perforated metal sheet; be careful not to bend it too much, otherwise it won't hold properly later.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Profile PM Email Garage |
26-02-2008, 17:50 Subject: GOLF 3 Brake Drum ABS |
Thank you for your help, it worked perfectly.
