Hoin Blaumann
Joined: 04/25/2002 Posts: 35 Karma: +6 / -0 Location: Langenkamp
26-11-2002, 21:16 Subject: Speedometer Calibration: Accurate & Reliable |
Can anyone tell me if it's possible to change the speedometer reading using the VW diagnostic tool (1551)?
Unfortunately, after installing a TDI PD engine (ATD, year 2000) in my T3 van, I don't have a working speedometer.
The Hall sensor and speedometer from a Golf IV, as well as various other components from the donor vehicle, have been installed. The sensor is connected to the speedometer shaft. The displayed speed is exactly 50% lower than the actual speed.
A factor needs to be modified to double the incoming signal.
Best regards, Hoin.
Düsen nicht dümpeln!!!
Translated on 28-09-2026, 18:32.
Profile PM Email |
Michael II Profi-Schrauber
Joined: 04/12/2002 Posts: 1132 Karma: +3 / -0 Location: Stuttgart
26-11-2002, 21:25 Subject: Speedometer Calibration: Accurate & Reliable |
Could you please provide the part number of the combined device? That way, we can look it up.
Tschüss
Michael II
Translated on 28-09-2026, 18:33.
Hoin Blaumann
27-11-2002, 9:35 Subject: Speedometer Calibration: Accurate & Reliable |
Hello Michael,
I don't have any diagnostic tools, so I can't give you a number.
The possibility of programming the software was suggested to me by an electrical engineer.
I'm not familiar with using tools like VAG-COM or software like 1551.
Best regards, Hoin.
Translated on 28-09-2026, 18:34.
Profile PM Email |
eike Guest
27-11-2002, 12:09 Subject: Speedometer Calibration: Accurate & Reliable |
The thing about the 50% display isn't that bad. You can quickly calculate how fast you are.
Does the odometer at least work, even if it's only half as fast?
Eike.
Translated on 28-09-2026, 18:35.
Hoin Blaumann
27-11-2002, 20:10 Subject: Speedometer Calibration: Accurate & Reliable |
"You're right, Eike, the odometer is also only showing half the correct mileage."
The other values, such as fuel consumption, average speed, and distance traveled, are also incorrect.
Hi.
Profile PM Email |
Uwe Profi-Schrauber
Joined: 04/15/2002 Posts: 1004 Karma: +5 / -0 Location: Westerwald
02-12-2002, 22:02 Subject: Speedometer Calibration: Accurate & Reliable |
Hi!
Under http://ha-projekt.de/, you can buy a frequency doubler for 49,- €.
Uwe
Kundenservice bedeutet bei Audi, die Kunden so schnell über den Tisch zu ziehen, daß sie die Reibungswärme als Nestwärme empfinden!
Translated on 28-09-2026, 18:36.
