AFN: Full Power?
der
Post09-07-2007, 17:31    Subject: AFN: Full Power? Quote
Hi, I recently bought a used 1997 A4 Avant with a 110PS TDI AFN engine, and I'm wondering if the engine is developing its full power. Subjectively, it feels a bit weaker than my old 35i with 90PS. I've created two logs using VAGCOM, and I was wondering if someone could take a look at them and tell me if the values seem plausible or if there might be a problem with the car.
Translated on 16-09-2026, 23:47.
Post12-07-2007, 23:26    Subject: AFN: Full Power? Quote
Based on your logs, everything appears to be okay. The LMM isn't performing optimally, but it's not yet exceeding the smoke limit and should be running at full power.
Guste.
Translated on 16-09-2026, 23:48.
der
Post15-07-2007, 10:26    Subject: AFN: Full Power? Quote
guste100 wrote:
According to your logs, everything appears to be okay. The LMM is not performing very well, but it is not yet exceeding the smoke limit, and it should be operating at full power.
Guste
OK, thank you icon_smile.gif. Are there significant differences in injection volumes between...?
"Driver preference" and the other two values are not so critical, or can be considered normal.
to consider? That's actually what made me feel uneasy, especially considering that they were particularly...
...occur at both low and very high speeds.
And are the LMM values also okay? I read that the target values of 850 are not...
actually, it corresponds to the fact that no more than 850 [characters/values] can be represented due to the 8-bit limitation.
"If we were to display them, the actual values might be too poor due to the uncertainty."
That's where the target value is.
Translated on 16-09-2026, 23:50.
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AVF facing massive problems, no performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN Engine Performance Data, MJ 1998 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Performance Issues: Troubleshooting & Solutions Diesel Engine Technology
No new posts AJM operating below full capacity - truly disappointing Diesel Engine Technology
No new posts AFN Performance Issues After ZKD Change? Diesel Engine Technology
No new posts VMax Speed Limit: What You Need to Know Diesel Engine Technology
