PD-TDI Replacement ECU | Control Unit
_Mike_
Post15-07-2007, 4:26    Subject: PD-TDI Replacement ECU | Control Unit Quote
I want to install a PD-TDI engine into a T3 without using the original engine control unit (ECU).
In the motorsport sector, there are "freely programmable" engine management systems for gasoline engines, and I was hoping that someone in this forum might know of companies or individuals who manufacture similar systems for diesel engines.
Thank you in advance.
Mike.
Translated on 31-10-2026, 23:42.
Post15-07-2007, 11:28    Subject: PD-TDI Replacement ECU | Control Unit Quote
Hello Mike,
Bosch Motorsport offers such products, but the price is completely irrelevant for a hobby project.
I can perform a reasonable adjustment with the engine control unit, possibly including a reduction in the maximum torque.
Actually, there's no real need to modify this motor with a custom-programmable system, because you can already modify all the necessary functions as desired using the standard engine control unit. Additionally, you have the advantage of already having a reasonable and tested foundation, so you don't have to reinvent the wheel.
Translated on 31-10-2026, 23:43.
_Mike_
Post15-07-2007, 18:46    Subject: ECU: Steuergerät kaufen | Steuergerät wechseln Quote
Hello Rainer,
You have a private message.
Mike.
Translated on 31-10-2026, 23:44.
No new posts VW T6, rear shock absorbers - replacement / weak performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LMM 038 906 461: Replacement for 06A 906 461 On-Board Diagnostics (OBD)
No new posts Outsmarted the STG again... LMM replacement Diesel Engine Technology
No new posts Coolant Level Sensor Replacement: Fix It Now! Diesel Engine Technology
No new posts Boost pressure sensor faulty - looking for replacement On-Board Diagnostics (OBD)
