ZKD AFN Leadership Pin 3070 - Solved
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
a4_afn
1997 Audi A4
Post09-09-2011, 13:53    Subject: ZKD AFN Leadership Pin 3070 - Solved Quote
Hey.
I need to replace the head gasket on my AFN engine after over 310,000 km. And when doing so, there are these guide dowels that you screw in to position the head. Is there another way to do it without using those guide dowels?
Is it sufficient to simply cut off two old cylinder head bolts and create a slot in them so that I can use a screwdriver to remove them, or will there be too much play in the hole, and will I not be able to properly center the cylinder head?
I would be very grateful for any tips.
Thank you very much for your answers.
"LG" is an abbreviation for "Liebe Grüße," which means "Best regards" or "Best wishes" in English.
Translated on 31-10-2026, 19:40.
Post09-09-2011, 14:19    Subject: ZKD AFN Leadership Pin 3070 - Solved Quote
Is there another way to do it without using the guide pin?
Yes, I cut off the old cylinder head bolts and made a slot in them... icon_wink.gif
Works perfectly.
and I can't really get my head centered
At least for the AHF, ALH, and ASV models, a sleeve is responsible for this. Either the AFN model doesn't have one, or it fell out and was lost during the removal of the control unit.
But even without that, it shouldn't be too much of a problem to just put a ZK (presumably referring to a cryptographic key) on the block.
Translated on 31-10-2026, 19:42.
a4_afn
1997 Audi A4
Post09-09-2011, 14:24    Subject: ZKD AFN Leadership Pin 3070 - Solved Quote
Works perfectly.
Best regards, Rainer
Hey.
Okay, that sounds great, that's exactly what I was hoping for.
Yes, those housings are not available at AFN. Instead, there's this special tool, model 3070, which you use to screw in two bolts, which can then be unscrewed again.
Thank you very much, best regards.
Translated on 31-10-2026, 19:44.
DieselBär30x
Avatar-DieselBär30x
Post09-09-2011, 21:58    Subject: ZKD AFN Leadership Pin 3070 - Solved Quote
Hello everyone!
Rainer's Tip works just as well as the 3070.
Yes, it is correct that centering sleeves are not included from the factory.
It is still highly recommended to carefully align the Z-axis to ensure a clean extrusion.
Otherwise, the rear wheel will not engage properly with the rear sprocket, which can lead to wear on the rear sprocket cover or, in the case of vehicles with ESP, on the ESP control unit (internally or externally).
Tip: Either align it using a protractor, ensuring the cylinder head gasket doesn't protrude, or fully screw in the truncated head bolts so that you can visually center them through the guide holes.
Best regards from Munich!
Translated on 31-10-2026, 19:46.
vwSchrauber
Post13-09-2011, 11:44    Subject: ZKD AFN Leadership Pin 3070 - Solved Quote
That would be news to me.
"Old" TDIs (those with the engine block featuring an intermediate shaft) typically have one (1) threaded insert in the center.
When installing the timing cover, it's important to ensure it's not twisted, otherwise the timing belt will quickly wear out. I usually use a steel ruler (or a flat bar, angle profile, or pipe) and align it with the injection pump rotor.
Translated on 31-10-2026, 19:47.
a4_afn
1997 Audi A4
Post13-09-2011, 12:11    Subject: ZKD AFN Leadership Pin 3070 - Solved Quote
OK, great, thanks for the tips.
I have one more question: What specifications do you adhere to regarding the cylinder head bolt tightening torques? Do you follow the guidelines of the vehicle manufacturers or the sealing manufacturers?
Because vehicle manufacturers are 40, 60, 90, 90 degrees.
Seal manufacturers: 40°, 60°, -90° + 60°, 90°, 90°.
Translated on 31-10-2026, 19:48.
BM
Avatar-BM
Post13-09-2011, 13:53    Subject: ZKD AFN Leadership Pin 3070 - Solved Quote
Basically, manufacturers.
"Who makes the screws? I only had one bad experience with Elring. Their screws couldn't withstand the second tightening angle (according to the VW manufacturer's instructions). Since then, I've only used original or Reinz products."
3B5 AJM
Translated on 31-10-2026, 19:49.
a4_afn
1997 Audi A4
Post13-09-2011, 14:16    Subject: ZKD AFN Leadership Pin 3070 - Solved Quote
Hopefully, the screws will hold icon_smile.gif; they are from Victor Reinz.
What do you mean by "manufacturer"? Do you mean the vehicle manufacturer or the seal manufacturer icon_wink.gif?
But think about seal manufacturers, right?
Translated on 31-10-2026, 19:50.
vwSchrauber
Post13-09-2011, 14:27    Subject: ZKD AFN Leadership Pin 3070 - Solved Quote
Normally, vehicle manufacturers. I seem to remember something about 40, 60, and two 90-degree angles from AFN as well. Or were they 30, 60, and two 90-degree angles? (which, actually, wouldn't matter...).
DieselBär30x
Avatar-DieselBär30x
Post13-09-2011, 17:29    Subject: ZKD AFN Leadership Pin 3070 - Solved Quote
Hello everyone!
All "older" TDIs (those with the block featuring an intermediate shaft) typically have one (1) dowel pin in the center. ...
...and he is naturally right, because the DBär was telling nonsense icon_wink.gif.
I just checked the photos of my earbud tips, and the sleeve is exactly where it's supposed to be (see photo below).
The AFN tightening torque specification of 40 Nm, 60 Nm, and 2 x 90° is correct.
I'm only familiar with those torque and angle specifications ("...60Nm, -90°, 60Nm...") from the soft seals used in (T)D engines, which aren't available on AFN engines. That's why I'm surprised to see something like that from the head gasket manufacturer.
I would also strongly advise you to follow the standard sequence and values for the assembly process.
 Paßhülse mittig im Block des AFN
 File size:  56.45 KB
 Viewed:  2758 times
Translated on 31-10-2026, 19:52.
a4_afn
1997 Audi A4
Post13-09-2011, 18:05    Subject: ZKD AFN Leadership Pin 3070 - Solved Quote
Okay, thanks for your help!
Then I will definitely dive into it this weekend icon_razz.gif.
Translated on 31-10-2026, 19:53.
BM
Avatar-BM
Post13-09-2011, 21:01    Subject: ZKD AFN Leadership Pin 3070 - Solved Quote
Oh, of course, I meant the values provided by the vehicle manufacturer.
Make sure the ZK (cylinder head) drains well (unless you disassemble it) when it's removed, so that oil doesn't get onto the sealing surfaces later when you reinstall it. Therefore, prepare everything carefully so that the ZK can be quickly screwed in/on before oil gets in. icon_wink.gif
3B5 AJM
Translated on 31-10-2026, 19:54.
a4_afn
1997 Audi A4
Post14-09-2011, 10:32    Subject: ZKD AFN Leadership Pin 3070 - Solved Quote
Make sure the ZK (if you're not disassembling it) drains well when it's removed, so that oil doesn't get on the sealing surfaces later when you reinstall it. Therefore, prepare everything carefully so that the ZK can be quickly screwed in/attached before oil gets in. icon_wink.gif
Great, thanks. Then I'll just let it bleed out icon_lol.gif icon_lol.gif icon_lol.gif.
What will be done with the head remains to be seen once it's detached.
Wie sind denn so eure Erfahrungen, müssen die TDI-Köpfe oft geplant werden? Heiß geworden ist er 1000% nicht, er drückt nur Öl seitlich raus aus der Kopfdichtung. Kühlflüssigkeit ist sauber und Schaum gibts auch keinen am Öleinfülldeckel bzw. MessstabBitte gib mir den Text, den du übersetzt haben möchtest.
Translated on 31-10-2026, 19:55.
vwSchrauber
Post14-09-2011, 17:27    Subject: ZKD AFN Leadership Pin 3070 - Solved Quote
What are your experiences regarding the TDI cylinder heads? Do they often need to be re-machined? It hasn't overheated at all, it's just leaking oil from the side of the cylinder head gasket.
Then let him plan, and you'll have a long period of peace afterwards.
Normally, the valve guides are also worn and need to be replaced if the valve seats are to be machined to a deeper recess.
Translated on 31-10-2026, 19:56.
a4_afn
1997 Audi A4
Post21-09-2011, 8:35    Subject: ZKD AFN Leadership Pin 3070 - Solved Quote
So, the ZKD has been replaced, and the AFN is working again icon_biggrin.gif.
I was really surprised at how good the AFN still looked with over 310,000 km, it should easily last another 300,000 km icon_wink.gif.
The valves were all in good condition and still sealing perfectly. The pistons and cylinder bores looked excellent.
Thank you for your help. The switch went smoothly and took approximately 6 hours.
Translated on 31-10-2026, 19:57.
BM
Avatar-BM
Post22-09-2011, 12:23    Subject: ZKD AFN Leadership Pin 3070 - Solved Quote
Okay, then - good luck and thank you for the feedback icon_lol.gif.
3B5 AJM
Translated on 31-10-2026, 19:58.
No new posts Golf3 pulls to the left (SOLVED) General Tips
This topic is locked, you cannot edit or reply. Synchronization angle 16V PD Germany (SOLVED) On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. ACV engine questions for the T4 (SOLVED) Diesel Engine Technology
This topic is locked, you cannot edit or reply. Understanding Question N75 (SOLVED) Diesel Engine Technology
This topic is locked, you cannot edit or reply. HDi Engine Performance Issues (Solved) Diesel Engine Technology
