Joined: 04/12/2002 Posts: 18135 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
24-05-2007, 21:03 Subject: EGR Valve for 2.0L TDI Engines |
Are there frequently occurring problems with the EGR valve on current 2.0L TDI engines?
I've already had two cars here that had a clear error code memory, but the readiness screen indicated a "defective exhaust gas recirculation system." The mileage was approximately 10,000 km and 50,000 km, respectively.
At least one of the two units definitely had a faulty check valve.
Why is the information related to readiness data not stored in the error memory?
I noticed these issues in each case because of implausible lambda sensor (LMM) data under full load, and in one car specifically because of the occasional black smoke (the other one had a DPF).
Translated on 17-09-2026, 7:28.
Profile PM WWW Garage |
24-05-2007, 21:21 Subject: EGR Valve for 2.0L TDI Engines |
Hello Rainer,
Which 2.0 models were they?
I could ask my brother-in-law about the BMR (16V DPF 125 kW) and the BMP (8V DPF 103 kW) models of his car.
Besides the beeping sound from the throttle valve, which is a component related to the EGR system, I haven't noticed anything else on the BMR.
Translated on 17-09-2026, 7:29.
Profile PM Garage |
25-05-2007, 8:54 Subject: EGR Valve for 2.0L TDI Engines |
Hi Martin,
Golf 5 and Skoda Octavia. Part numbers: 03G906021JG and ???. Likely BMM/BMP engines.
Translated on 17-09-2026, 7:30.
matthiasTDI96 Profi-Schrauber
25-05-2007, 9:34 Subject: EGR Valve for 2.0L TDI Engines |
"Our BMP (likely referring to a diagnostic tool) will also be used to read the data... however, it has only been driven 1850 km. Rainer, you mentioned broken AGR (Exhaust Gas Recirculation) pipe connections recently. Did that affect the same engines?"
Translated on 17-09-2026, 7:31.
ObenbeiMutti Guest
25-05-2007, 9:43 Subject: EGR Valve for 2.0L TDI Engines |
In my opinion, that was the 1.9-liter engine with 105 horsepower.
@Rainer
Is there already, or is there any possibility of, an electronic programming solution or replacement circuit to disable the throttle valve and the EGR system?
without the engine going into emergency mode, or without it being detected during the emissions test.
That's not a condition, regardless of the manufacturer.
25-05-2007, 10:17 Subject: EGR Valve for 2.0L TDI Engines |
matthiasTDI96 wrote: | | Our BMP will also be read out sometime... however, it has only run 1850 km. Rainer, you mentioned broken AGR pipe connections recently. Did that affect the same engines? |
It was a BKC...
Translated on 17-09-2026, 7:32.
christians Profi-Schrauber
26-05-2007, 21:57 Subject: EGR Valve for 2.0L TDI Engines |
Could that be the reason why some engines need to regenerate their DPF so frequently, as has been reported?
Gruß Christian
Translated on 17-09-2026, 7:33.
18-06-2007, 15:29 Subject: EGR Valve for 2.0L TDI Engines |
christians wrote: | | Perhaps that is the reason why some engines need to regenerate their DPF so frequently, as has been mentioned before? |
It's quite possible... today, another 2.0 TDI with a throttle body problem, specifically the BKD engine. The turbocharger boost control is completely messed up as long as the EGR valve is active.
engl Guest
15-08-2007, 20:02 Subject: EGR Valve for 2.0L TDI Engines |
With the BKD engine, you can disable the AGR (Abgasrückführung) by blocking the vacuum control line. It takes about 5 seconds. The engine response below 2000 RPM will then be noticeably better, but still not amazing!
Translated on 17-09-2026, 7:34.
15-08-2007, 20:27 Subject: EGR Valve for 2.0L TDI Engines |
engl wrote: | | With the BKD engine, you can disable the AGR (Exhaust Gas Recirculation) by blocking the vacuum control line. It takes about 5 seconds, and the acceleration below 2000 RPM is noticeably better, but still not amazing! |
The control unit detects this and stores a corresponding error code.
Translated on 17-09-2026, 7:35.
Boro Guest
16-08-2007, 6:37 Subject: EGR Valve for 2.0L TDI Engines |
'This recently happened to my brother's car! It's a Touran 2.0, manufactured in December 2004, with approximately 45,000 km on the odometer. The dashboard displayed an error message about the exhaust gas recirculation system, but there were no error codes stored in the system.'
It was repaired free of charge by VW..., a new valve was installed!
Translated on 17-09-2026, 7:36.
