G4 Driveshaft: Replacement & Parts
Bolzer
Karma: +14 / -0   Thank you, like it!
Post18-07-2007, 5:19    Subject: G4 Driveshaft: Replacement & Parts Quote
Hi.
"A long time ago, I installed the 6-speed gearbox from the ARL engine into my G4 ASV, along with the corresponding drive shafts. Now, the right drive shaft is about to fail. Do I absolutely need to use the drive shaft from the 150 HP ARL engine again, or can I also use the one from the 130 HP ASZ engine? Are there any physical differences (length, thickness, etc.)?"
Best regards, Bolzer.
Translated on 01-10-2026, 1:29.
DariusPolo
Post18-07-2007, 5:40    Subject: G4 Driveshaft: Replacement & Parts Quote
The engine from the ASZ (130 hp) is very similar to the one from the ARL (150 hp), and they are compatible with each other.
Darius.
Translated on 01-10-2026, 1:30.
Bolzer
Post18-07-2007, 6:09    Subject: G4 Driveshaft: Replacement & Parts Quote
Hi.
Thank you for the quick response. Then I can order the wig right away.
Bolzer.
Translated on 01-10-2026, 1:31.
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts Drive shaft replacement: Is it covered? Diesel Engine Technology
No new posts Part Number Driveshaft Transmission, Chassis, Body & Interior
No new posts G3 GTD Driveshaft Vibration Dampener (AAZ) Transmission, Chassis, Body & Interior
No new posts Drive shaft removal Transmission, Chassis, Body & Interior
