Valve Stem Seal Tools: Repair & Replacement
luiggi
Post07-02-2008, 17:42    Subject: Valve Stem Seal Tools: Repair & Replacement Quote
HELLO,
I need to replace the head gasket on a Deutz engine soon (due to significant oil leakage). I'm also going to replace the valve stem seals at the same time. Question: Unfortunately, I don't have any specialized tools available (like the lever used to depress the springs). Does anyone know of a way to do this without that tool, so I can compress the springs and remove/reinstall the tapered pieces? Thanks.
Translated on 21-08-2026, 4:27.
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post07-02-2008, 18:20    Subject: Valve Stem Seal Tools: Repair & Replacement Quote
Yes:
weld one yourself from a large C-clamp.
You should be able to bend two windows from the appropriate pipe to press down on the disc. The screw handle should face towards the valve disc!
Should I start a series? Anyone interested? No, just do it yourself; it's cheaper.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 21-08-2026, 4:29.
christians
Post08-02-2008, 12:57    Subject: Valve Stem Seal Tools: Repair & Replacement Quote
I'm using a section of pipe with a window that is pressed down by a drill attached to the drill stand.
Gruß Christian
luiggi
Post08-02-2008, 18:41    Subject: Valve Stem Seal Tools: Repair & Replacement Quote
Great!
That's the idea with the drill. I will bend a bracket or cut a window from a pipe, and then press the whole thing down using a standing drill press. This works very well for me because my machine has a feed mechanism, which automatically holds the position. !! Thanks again. icon_idea.gif
Translated on 21-08-2026, 4:30.
No new posts Tool durability test: Does it last? Diesel Engine Technology
No new posts LLM Migration Tool: Simplify Your Switch Diesel Engine Technology
No new posts Tool for adjusting distributor injection pumps VW Diesel Engine Technology
No new posts Vehicle Front Alignment Tool for Service Diesel Engine Technology
