michi22 Blaumann
Joined: 10/27/2007 Posts: 18 Karma: +1 / -0 Location: Wien 1998 Audi A4 Free account, no CAN development support
14-01-2008, 16:15 Subject: A4 2.5 TDI: No Compression in Cylinder 2 |
After the car started misfiring, I took it to a VAG workshop. They found that cylinder 2 (on the right bank of cylinders) has zero compression. What could be the possible causes?
I drove another 100 kilometers in that condition.
Michi
Translated on 12-08-2026, 12:10.
Profile PM Garage |
Steffarn Profi-Schrauber
18-01-2008, 16:36 Subject: A4 2.5 TDI: No Compression in Cylinder 2 |
Why don't you disassemble it and see what's broken?
There probably aren't many possible causes. It's likely a valve problem.
Or the piston is faulty.
Step 1: Remove the valve cover.
Step 2: Lower your head.
If it's related to the piston, there is usually also a very high KGH pressure.
B.Eng (FH) u. KFZ Meister
Translated on 12-08-2026, 12:12.
Profile PM Email Garage |
moonlight Guest
22-01-2008, 18:12 Subject: A4 2.5 TDI: No Compression in Cylinder 2 |
I just wanted to add my two cents. I had the same problem, but it was with cylinder 4 on a 1.9 TDI AFN engine, and in my case, the piston was cracked. My sincere condolences  .
Translated on 12-08-2026, 12:13.
22-01-2008, 20:14 Subject: A4 2.5 TDI: No Compression in Cylinder 2 |
moonlight wrote: | I just wanted to chime in and say that I had the same problem, but with cylinder 4 on a 1.9 TDI AFN engine, and in my case, the piston was cracked. | My condolences.
Interestingly, the fourth piston in my AFN engine is also cracked.
That's funny.
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1513 Karma: +647 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
27-01-2008, 9:55 Subject: A4 2.5 TDI: No Compression in Cylinder 2 |
Steffarn wrote: | moonlight wrote: | I just wanted to chime in and say that I had the same problem, but with cylinder 4 on a 1.9 TDI AFN engine, and in my case, the piston was cracked. My sincere condolences  | .
It's so funny. |
In our company's air handling unit (AHU), the fourth one was also damaged.
Translated on 12-08-2026, 12:14.
Profile PM Garage |
Arno Guest
27-01-2008, 14:55 Subject: A4 2.5 TDI: No Compression in Cylinder 2 |
I just wanted to chime in and say that I had the same problem, but with cylinder 4 on a 1.9 TDI AFN engine, and in my case, the piston was cracked. My sincere condolences  .
It's so funny.
@moonlight and Steffarn:
Under what circumstances did this happen, or what was the cause of it tearing (tuning, constant full throttle on the highway, injector failure, etc.)?
Translated on 12-08-2026, 12:16.
27-01-2008, 21:14 Subject: A4 2.5 TDI: No Compression in Cylinder 2 |
"Well, the crack went right across the piston, directly above the wrist pin. It probably couldn't handle the 160 horsepower and simply split open. The four new pistons had a brass ring fitted around the wrist pin, which the old pistons didn't have. Everything else was made of aluminum. That was probably sufficient for 110 horsepower."
Translated on 12-08-2026, 12:17.
michi22 Blaumann
27-01-2008, 22:43 Subject: A4 2.5 TDI: No Compression in Cylinder 2 |
Now the heads are facing down, and you can't see any damage to either the pistons or the valves.
The workshop also found that the ESP (Electronic Stability Program) is malfunctioning because it can no longer rotate freely without significant effort.
Profile PM Garage |
28-01-2008, 5:17 Subject: A4 2.5 TDI: No Compression in Cylinder 2 |
michi22 wrote: | so now the heads are facing down and you can't see any damage on either the pistons or the valves.
The workshop also found out that the ESP is broken because it can no longer rotate without requiring significant force. |
There has to be some explanation for the 0 bar compression reading!
It's suspicious that two things are happening at the same time. The jerking could be caused by the ESP (stability control) or an injector. However, it's hard to imagine that two cylinders would fail simultaneously.
What do the young people at the workshop suggest doing?
Translated on 12-08-2026, 12:19.
cksIT Blaumann
Joined: 05/22/2004 Posts: 399 Karma: +18 / -0 Location: Riedstadt
28-01-2008, 11:09 Subject: A4 2.5 TDI: No Compression in Cylinder 2 |
Why do I suddenly have the feeling that the compression wasn't actually zero???
Even if the head gasket is blown, the compression test should still show something.
It's not uncommon for the ESP (Electronic Stability Program) to fail in that engine.
Translated on 12-08-2026, 12:20.
matthiasTDI96 Profi-Schrauber
28-01-2008, 13:43 Subject: A4 2.5 TDI: No Compression in Cylinder 2 |
If your car is currently at the diagnostic workshop, I'm afraid that's when your problems will really begin.
A compression value of zero doesn't just happen spontaneously. This can only occur if, as described, a valve is leaking or a piston ring/piston is severely damaged. If everything appears to be in order visually, the measurement is highly questionable. I also find the ESP diagnosis very doubtful. However, it is certainly an indication if there are unnatural resistances to overcome.
But if this only becomes apparent after disassembly, that's already questionable, because the stuttering could indicate a problem with the ESP (Electronic Stability Program) or the injectors.
Here's a simple question: Could it be that the fuel injector of the affected cylinder wasn't screwed in during the compression test, for testing purposes?
Translated on 12-08-2026, 12:21.
cksIT Blaumann
28-01-2008, 13:54 Subject: A4 2.5 TDI: No Compression in Cylinder 2 |
Personally, if the pistons and valves look okay, I would have the car towed to another workshop and get a second opinion, because, as I said, it's practically impossible for the compression to be zero.
It sounds like someone is trying to make money off this. If the other workshop confirms this, I would hire a lawyer because it's not just about 10 euros here!
Translated on 12-08-2026, 12:22.
christians Profi-Schrauber
28-01-2008, 16:34 Subject: A4 2.5 TDI: No Compression in Cylinder 2 |
The VP44 must indeed be relatively easy to turn.
Could it be that a faulty hydraulic lifter temporarily kept a valve open? They're not exactly durable in the V6 TDI engines. Based on my feeling, I would say the oil pressure might not be sufficient for that. On the other hand, the new cylinder heads have pressure relief valves, which Audi includes for a reason.
Gruß Christian
Translated on 12-08-2026, 12:23.
michi22 Blaumann
28-01-2008, 17:55 Subject: A4 2.5 TDI: No Compression in Cylinder 2 |
The compression was measured by a VAG workshop, and they found it to be 0 bar.
The workshop where the car is currently located can't explain the zero compression and believes that VAG made a mistake. VAG only removed the glow plugs for the compression test; the injectors were left in place.
The valve lifters and the camshaft are worn, but nothing is broken. I took the pump to a specialist who will inspect it (I expect his answer tomorrow).
Whether the valves are damaged in any way can be determined at the latest when disassembling the cylinder head (for resurfacing).
The pistons have no cracks, and the cylinder walls also appear to be in good condition.
The writing also looked okay.
I will have the exhaust manifold refurbished (450 euros from Poland) and then, a friend of mine will apply a chrome plasma coating to it (8 micrometers thick - they also coat pistons with it).
Here are a few pictures of the engine:
http://michi22.mi.funpic.de/A4/1jpg.jpg
http://michi22.mi.funpic.de/A4/2.jpg
http://michi22.mi.funpic.de/A4/3.jpg
http://michi22.mi.funpic.de/A4/4.jpg
http://michi22.mi.funpic.de/A4/5.jpg
http://michi22.mi.funpic.de/A4/6.jpg
http://michi22.mi.funpic.de/A4/7.jpg
Should it actually turn out that the ESP was faulty and not cylinder 2, then can I sue VAG because they were the ones who removed the two heads? [url][/url]
Translated on 12-08-2026, 12:25.
Profile PM Garage |
cksIT Blaumann
28-01-2008, 18:14 Subject: A4 2.5 TDI: No Compression in Cylinder 2 |
Whether it will actually come to a lawsuit remains to be seen, but at the very least, I can cause you some trouble. Since you have everything on record, it's quite possible to prove that the compression wasn't 0 bar.
because if the pistons are in good condition and the valves look okay initially, then you should also measure the compression (maybe not fully, but at least something).
Translated on 12-08-2026, 12:27.
BM Profi-Schrauber
Joined: 12/07/2005 Posts: 1857 Karma: +8 / -0 Location: Nähe Düsseldorf
28-01-2008, 18:55 Subject: A4 2.5 TDI: No Compression in Cylinder 2 |
Quote: | | because if the pistons are okay and the valves initially look good, then you should also measure compression! | (maybe not fully, but at least something).
"I agree. I don't understand why a pressure test wasn't performed before removing the head. That would immediately reveal whether and where any pressure is being lost. Now we're just guessing. Since the cylinder head has already been removed, I would also pull out the piston to make sure there isn't any damage."
3B5 AJM
Translated on 12-08-2026, 12:28.
