Clean Poop-Soiled Diaper: Guide & Tips
Post29-07-2007, 9:23    Subject: Clean Poop-Soiled Diaper: Guide & Tips Quote
Sure.
"The Little One" did it, he finally got to drive my Passat.
Under the child seat, I had quite a few towels icon_twisted.gif, but the strap was lying unprotected in the... sun.
What can I use to clean it / what should I absolutely not use to clean it, so that it no longer smells but still lasts?}
Greetings.
Translated on 20-10-2026, 6:46.
Post29-07-2007, 10:35    Subject: Clean Poop-Soiled Diaper: Guide & Tips Quote
And you said...nothing will happen icon_wink.gif.
Based on my experience (though not long-term testing): Use plenty of water, a neutral cleaner, and then, like the old-fashioned way, wipe it down with a cloth and let it dry.
Welcome to the club!
Translated on 20-10-2026, 6:47.
Jochen_145
Post29-07-2007, 11:12    Subject: Clean Poop-Soiled Diaper: Guide & Tips Quote
Hello Martin,
Based on my experience, I can support Matthias' suggestion.
The best way to do it is with neutral soap and a nail brush.
I agree with that icon_confused.gif.
Best regards, Jochen.
Translated on 20-10-2026, 6:48.
R.M.
Karma: +14 / -0   Thank you, like it!
Post29-07-2007, 20:34    Subject: Clean Poop-Soiled Diaper: Guide & Tips Quote
"...but please don't rub too hard with the brush. Otherwise, the piece of webbing will look like a felt carpet. It's better to first try using a cloth and possibly some kernel soap. There's no gentler way."
Translated on 20-10-2026, 6:49.
haithamina
Post30-07-2007, 10:21    Subject: Clean Poop-Soiled Diaper: Guide & Tips Quote
Hi, as someone who has experienced this multiple times: residue left after soap baths usually comes out very well with a (upholstery/carpet) stain remover.
I suspect "he" was in a car seat, i.e., facing backwards? As they grow bigger, the vomiting rate decreases, and then they can sit facing forward! These high-seas hats with neck protection are really trendy! icon_lol.gif
haithamina
Post30-07-2007, 10:39    Subject: Clean Poop-Soiled Diaper: Guide & Tips Quote
No.
He was sitting in the brand new Römer Kidfix, and he complained so much that his French mineral water was disgusting, until he thought he had to prove it. icon_evil.gif
Thanks to the vomit-deflecting shield (hand over the mouth), most of it ended up on him... and, of course, on the belt.
Ah, one more tip: The thing about putting coffee grounds in the car actually works.
Now not only are my cushions "latte macchiato" colored, they also smell like it.
You just have to make sure you don't put your nose too close to the seatbelt on the right side of the back seat.
Tonight, it's time for digging out the sand and washing the belts.
Translated on 20-10-2026, 6:51.
cksIT
Post30-07-2007, 13:15    Subject: Clean Poop-Soiled Diaper: Guide & Tips Quote
There's not much better you can recommend for the smell than Febreze. This stuff really works. For cleaning, you can also use diluted vinegar (it evaporates, and after treating it with Febreze, it should be okay again).
It's even more annoying when it happens with a new car icon_smile.gif.
Translated on 20-10-2026, 6:52.
wolfi_b
Post30-07-2007, 13:54    Subject: Clean Poop-Soiled Diaper: Guide & Tips Quote
You could also submerge a belt in a bucket of water and give it a hand wash.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 20-10-2026, 6:53.
Post30-07-2007, 14:05    Subject: Clean Poop-Soiled Diaper: Guide & Tips Quote
Now,
Where I expanded the seating area, that works.
Because the strap was "stuck" just before the lower attachment point... and I would have definitely spilled that bucket of water onto the upholstery.
Post02-08-2007, 15:31    Subject: Clean Poop-Soiled Diaper: Guide & Tips Quote
Okay, so...
Seat is back in (almost perfectly clean).
Bought Febreze.
If there are no tremors later, the belt will be cleaned and sterilized.
Thank you for the tips.
Translated on 20-10-2026, 6:54.
No new posts Removing and cleaning a diesel particulate filter (DPF) Troubleshooting & Guides
No new posts Clean Vintage: Restoring & Repairing Old Items Diesel Engine Technology
No new posts DPF reinigen? Diesel Engine Technology
No new posts BPP DPF Cleaning Diesel Engine Technology
No new posts Clean LMM: How to Clean Your LMM. Diesel Engine Technology
