Passat, model year 2000: Brakes stuck, brakes overheating.
Affected vehicle identification numbers:
Up to 12.99; incl. VAT. Number: 3BYE 240 844
Until 4:00 AM; Background. Number: 3BYE 394 536
Cause:
Production-related tolerance ranges.
Solution:
The brake booster must be connected without any tension.
- Loosen the screw on the bearing bracket.
- Loosen the screws that connect the bearing bracket to the master cylinder and the brake booster.
- Move the brake booster back and forth to allow for stress-free installation.
- First, tighten the fittings, and then tighten the screw on the bearing bracket, being sure to observe the specified torque.
- Then, adjust the brake light switch.
Tschüss
Michael II
