E-Gas Sensors: Resistors vs. Inductors
yellow5
Post30-08-2007, 9:38    Subject: E-Gas Sensors: Resistors vs. Inductors Quote
Which throttle position sensor does the ARL engine use?
Based on the circuit diagram, it should be a potentiometer.
I once read somewhere that inductive sensors are also used in VAG engines.
Does anyone know anything about that?
Sure, no problem.
Best regards, Franz.
Translated on 01-10-2026, 22:14.
Post30-08-2007, 9:41    Subject: E-Gas Sensors: Resistors vs. Inductors Quote
Are you perhaps confusing the potentiometer and inductive sensors used in the VP injection pumps?
Translated on 01-10-2026, 22:15.
yellow5
Post30-08-2007, 9:49    Subject: E-Gas Sensors: Resistors vs. Inductors Quote
No, I mean the accelerator pedal.
Should there be gas pedals with inductive sensors or with potentiometer (resistance) sensors?
I need to know which of the ARLs is required.
Maxx1278
Avatar-Maxx1278
Post30-08-2007, 12:23    Subject: E-Gas Sensors: Resistors vs. Inductors Quote
I also can't tell you what's inside (according to the service manual, it's a potentiometer).
According to the AKTE documentation, it is the "electronic accelerator pedal module" with part number 6Q1 721 503 H.
Costs 53.90 EUR excluding VAT.
Sure, Maxx.
Translated on 01-10-2026, 22:16.
Post30-08-2007, 13:57    Subject: E-Gas Sensors: Resistors vs. Inductors Quote
Okay, as far as I know, for the 1.9 TDI engines, the only sensors available for the pedal are potentiometer sensors.
Translated on 01-10-2026, 22:17.
Jochen_145
Post30-08-2007, 14:29    Subject: E-Gas Sensors: Resistors vs. Inductors Quote
Actually, it has to be a potentiometer, because an inductive sensor only provides a signal when the sensor wheel is rotating.
Therefore, constant pedal positions would be indicated by a 'zero signal,' which makes the analysis too complicated.
AFAIK, two potentiometers that operate in opposite directions are always used on the pedal, which allows for quick identification of cable breaks or implausible signal issues.
Best regards, Jochen.
Translated on 01-10-2026, 22:18.
Post30-08-2007, 15:52    Subject: E-Gas Sensors: Resistors vs. Inductors Quote
The RWG also gives a signal if the register slide is not moved icon_wink.gif.
AFAIK, there are always two potentiometers installed on the pedal, working in opposite directions, so that cable breaks and implausible signals can be identified very quickly.
Hmm... all the 1.9 TDI SLPs I've seen so far have a simple potentiometer with idle and kickdown contacts for plausibility checking.
Translated on 01-10-2026, 22:19.
yellow5
Post30-08-2007, 17:26    Subject: E-Gas Sensors: Resistors vs. Inductors Quote
Here's something I found, but it's about a 2.0-liter TDI engine.
Enter this text into Google: g79 gaspedalstellung induktiv
Then, click on the second link, which is a PDF. On page 29, you can find an inductive sensor like that.
I'm hoping, or rather, I think it's not installed in the 1.9 version.
The problem is as follows: I'm experiencing something similar to what's described in the SLP.
connected the accelerator pedal sensor from the original 1Z/AHU engine to the ARL engine, but...
The control unit indicates that it is not functioning.
That's why I thought it might be one of the newer models.
Translated on 01-10-2026, 22:21.
Malte1408
Post30-08-2007, 18:26    Subject: E-Gas Sensors: Resistors vs. Inductors Quote
Therefore, constant pedal positions would be indicated by a "zero signal," which makes the analysis too complicated.
AFAIK, two potentiometers that work in opposite directions are always used on the pedal, which allows for quick identification of cable breaks or implausible signal issues.
Who says that "inductive" necessarily means "rotary encoder"? You can achieve the same result using other methods.
Translated on 01-10-2026, 22:22.
Jochen_145
Post30-08-2007, 21:46    Subject: E-Gas Sensors: Resistors vs. Inductors Quote
actually, it must be a potentiometer, because an inductive sensor only provides a signal when the sensor wheel is rotating.
Who says that inductive means encoder wheel, you can do something else.
'Classical' inductive pickups are passive components that generate their output voltage based on a changing magnetic field.
If I'm using an 'active' component that utilizes a generated base alternating field, it is perfectly functional.
However, I did not use active inductive modules, but rather a classic inductive sensor icon_eek.gif.
So, it seems we've been describing different things.
Hm... all the 1.9 TDI-SLP units I've seen so far have a single potentiometer with idle and kickdown contacts for plausibility checking.
Please don't fix this now, as I don't currently have access to SSP 210.
Possibly, I may have confused it with a different manufacturer. icon_confused.gif
Translated on 01-10-2026, 22:24.
Post31-08-2007, 7:55    Subject: E-Gas Sensors: Resistors vs. Inductors Quote
Can the electrical design be fixed to the mechanical structure?
Gas pedal pressed = Potentiometer.
Gas pedal held down (as shown in the PDF) = Inductive.
Translated on 01-10-2026, 22:26.
Malte1408
Post31-08-2007, 12:33    Subject: E-Gas Sensors: Resistors vs. Inductors Quote
dieselmartin wrote:
Can the electrical design be attached to the mechanical design?
I mean, I think there's one with Hall sensors.
Translated on 01-10-2026, 22:27.
yellow5
Post04-09-2007, 10:48    Subject: E-Gas Sensors: Resistors vs. Inductors Quote
It appears that the gas sensor from ARL is also a potentiometer.
The one installed is the 1Z/AHU version.
I'd really like to avoid replacing this sensor, because the new one is a...
and has a different design and wouldn't necessarily fit.
Does anyone know if the resistance values have changed?
from the old design to the new design?
Translated on 01-10-2026, 22:28.
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Passat 3C or Superb 3T emergency unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Retrofitting ESD/ASR for Audi A4 Diesel Engine Technology
No new posts Short Buy Strategy: Is It Working for You? Diesel Engine Technology
No new posts Tuned ASZ: Vibration Issues - ZMS or Engine Mounts? Diesel Engine Technology
No new posts Clicking noise from the engine or belt system on ARL TDI,... Diesel Engine Technology
