Steering Angle Adjustment Not Possible
3 Phasen Biber
Karma: +2 / -1   Thank you, like it!
2001 Volkswagen Golf
Post03-08-2007, 16:07    Subject: Steering Angle Adjustment Not Possible Quote
The following problem: GRA (presumably a system) was installed => steering angle sensor was damaged => a new one was purchased from an online marketplace => it cannot be adjusted. icon_evil.gif
I followed all the instructions as described, but I'm getting the error: "Adjustment not possible!"
I'm stuck now, does anyone have any ideas what might be causing this?
Data:
VAG-COM Version: Release 311.2-N.
Control Module Part Number: 1C0 907 379 E
Component and/or Version: ESP FRONT MK60 0104
Software Coding: 0019970
Workshop Code: WSC 01317
2 Faults Found:
00778 - Steering Angle Sensor (G85)
003 - Mechanical Failure - Intermittent
005 - No or Incorrect Basic Setting / Adaptation.
Mechanical fault?! Does this mean the steering angle sensor is misaligned or defective?
ehemals G4 ASZ, jetzt G4 ARL
Translated on 30-08-2026, 23:44.
Post03-08-2007, 21:35    Subject: Steering Angle Adjustment Not Possible Quote
Well, a dictionary helps: Sporadic mechanical failure. There's probably a reason why this part ended up for sale online...
Translated on 30-08-2026, 23:46.
Ross-Tech-Support
Post03-08-2007, 22:40    Subject: Steering Angle Adjustment Not Possible Quote
Our WIKI also has the answers...
http://wiki.ross-tech.com/index.php/00778
3 Phasen Biber
Post04-08-2007, 16:38    Subject: Steering Angle Adjustment Not Possible Quote
Could it be that he's confused?
I determined the center point before installation.
Translated on 30-08-2026, 23:47.
Ross-Tech-Support
Post05-08-2007, 15:50    Subject: Steering Angle Adjustment Not Possible Quote
3 Phasen Biber wrote:
Could it be that he is twisted?
Perhaps it's possible, or maybe you should just ask someone who knows about it.
3 Phasen Biber
Post12-08-2007, 12:55    Subject: Steering Angle Adjustment Not Possible Quote
Good idea, are you familiar with it? icon_evil.gif Unfortunately, I don't know anyone who can help, and I don't want to take the car to the workshop.
I've learned all of this information from this forum. It's also one of the reasons why I ended up here and not in a forum dedicated to spoilers or wide tires.
Translated on 30-08-2026, 23:48.
3 Phasen Biber
Post12-08-2007, 19:06    Subject: Steering Angle Adjustment Not Possible Quote
For those who are still interested: the solution to the problem icon_smile.gif
@ Rainer
@ all
I used VAG-com to determine the steering angle and adjusted it until it displayed zero degrees. Then, I adjusted the steering wheel and made the necessary steering angle adjustments.
P.S. The central position of the dispenser was certainly not icon_evil.gif.
Thank you to the forum; the knowledge that has been collected here is enormous icon_biggrin.gif.
Translated on 30-08-2026, 23:49.
mserge
Post14-08-2007, 15:26    Subject: Steering Angle Adjustment Not Possible Quote
Hello, what do you understand by "adjusting the steering angle"?
Does that refer to the zeroing of the steering angle sensor? There's a specific procedure for that that involves using Vag-***.
I hope you didn't mess up the steering's zero point when you turned the steering wheel, otherwise, the steering wheel will be misaligned and you'll have to turn it to drive straight.
Have you ever tried turning the wheel fully to the left and fully to the right and checked the values? If the sensor isn't centered, you might get an implausible signal when you turn the wheel all the way.
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 30-08-2026, 23:50.
3 Phasen Biber
Post17-08-2007, 11:36    Subject: Steering Angle Adjustment Not Possible Quote
No, that's not what I meant. No, I determined a value of 0° in the MWB (which is approximately the center of the sensor) and then reinstalled the steering wheel.
Translated on 30-08-2026, 23:51.
No new posts Zero-tolerance for deviations in the steering angle of th... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zero offset for accelerator pedal angle sensor (G85) in B... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Adjusting Glow Plug Timer on VAG TDIs Troubleshooting & Guides
No new posts Fuel Injector Adjustment: Troubleshooting & Help! On-Board Diagnostics (OBD)
No new posts Throttle learning not possible Gasoline Engine Technology
No new posts Audi V8 D11: Diagnosis Not Possible On-Board Diagnostics (OBD)
No new posts Passat 3B ABS FS reading not possible! On-Board Diagnostics (OBD)
